Old 05-05-2009   #1
iceminion
iceminion's Avatar
New ride off craigslist
I just picked up an amazing deal off craigslist.
-93 Red summit 3-door.
-1.8L 5-speed.
-One spot of rust.
-4 new tires
-tow hitch (class II)
126,000
He was asking $200, I was a total a**hole and got him down to $160, I feel so bad *not*
Transmission goes into 1234 no 5 or R
I assume the issue with the transmission is the nut that backs off all DSM transmissions, i know this is a CSM, but w/e....does anyone have any experience with these?
building a 3000GT AWD Turbo.
Old 05-05-2009   #2
Re: New ride off craigslist
not bad the nut does back off them. If it ends up being a tranny problem you will have a hard time finding one. the 1.8 csm are hard to find a 1.8 5 speed hydro tranny
Old 05-05-2009   #3
iceminion
iceminion's Avatar
What is a 5 speed hydro tranny?
Old 05-05-2009   #4
90% of the csm use a cable clutch style tranny and the 1.8 5speeds with the hydo tranny (just like dsm's) are very hard to find not many were made
Old 05-05-2009   #5
I actually had the nut completely just shear off with part of the shaft still in it on one of my transmissions
Old 05-05-2009   #6
Stop knowing so many random facts.
Old 05-05-2009   #7
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
x2, but now Im curious as to if you will know the answer to the tranny question.
Old 05-05-2009   #8
iceminion
iceminion's Avatar
Holy crap TKR FTW.
I have done a clutch on one of these f*uckers before, from what I remember it did NOT have a cable, it had a hydraulically actuated slave cylinder.
I could be wrong, ill check.
Will any FWD DSM/CSM transmission work? out of a 1.6/1.8/2.0/2.4?
Old 05-05-2009   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I am pretty sure your answer is no. You should have waited to buy one. I will be selling my shell when I get my ass outside to take pics and come up with a price. Mine is a 4G61T and already had a dsm motor in it. It is also going to come with an aftermarket exhaust, guages, a walbro pump, and aftermarket rims. If your plans are 4G63, it won't jsut drop into that car without modification.
7/25/09
Old 05-05-2009   #10
iceminion
iceminion's Avatar
My plans are FUEL ECONOMY.
I am going to try to re-attach the nut that may have spun off, and hopefully, that should fix the issue.
Old 05-05-2009   #11
Double check that there is a proper crush washer on the reverse light switch. Without it, you cannot get into 5th or reverse. Must be like at least .100" or taller.
Old 05-05-2009   #12
iceminion
iceminion's Avatar
The owner did not do any work on it, he invested a crap ton in it, when it stopped going into 5 and R he brought it to a transmission shop, they quoted him $1200, he gave up on it.
Thanks for the info sleepy, its good to know
Old 05-05-2009   #13
iceminion
iceminion's Avatar
I can has Saturn? http://en.wikipedia.org/wiki/Mitsubishi_Saturn_engine
FFFFFFUUUUUUUUUUUUUUCCCCCCCC......
so I am guessing all sirius engine bolt patterns are not compatible.
Old 05-05-2009   #14
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Jack the FWD tranny off a 1.8 eclipse.
Old 05-05-2009   #15
Gravy
Who's this guy?
Do you still have yours at home? Or has that thing finally gone to the large junk yard in the ground Febo?
Old 05-05-2009   #16
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
That one at home has a blown tranny, the motor might still be good tho.
Old 05-05-2009   #17
you can use a 1.8 or 1.5 mirage tranny bolt in
the dsm 1.8,2.0,2.4 will not work on the csm 1.8
but if you go to a 4g63 you can use
dsm 1.8
csm 1.5 with n/a 4g63 fly and clutch
csm 1.8 with n/a 4g63 fly and clutch
2g fwd turbo tranny bolt in
1g fwd turbo or n/a will need custom mounts (that i make)
to put a 4g63 in it. you will need 2g block mount and upper engine mount ,or the same set out of a 4g64 galant. 1g awd mount the bolts to the tranny. take out the 1.8 tranny mount that is on the frame and flip it 180 and bolt it back on. roll stops work for 2g trannys other wise you will need to make or buy mount for a 1g tranny
Old 05-05-2009   #18
damn, can you make mounts to make a 1g tranny fit in a 2g? lol
Old 05-05-2009   #19
it can be done but, it is a pain in the ass. you need the awd 6 bolt block mounts,modbthe roll stop brace and make mounts. it would be cheaper to get a 2g tranny.
