Old 05-29-2009   #1
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Weird boosting problems
So I hadn't had this problem before, before I threw a new intake on the car. It's pulls nice, boosts nice through 2nd. When I get on it in 3rd, the boost comes on, and the revs go up without it pulling. Clutch slip? Like I said this all happened after I put an air filter on.
Old 05-29-2009   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Weird boosting problems
It's the clutch. The intake was probly a coincidence.. Does it do it in 4th gear also?
-1990 Mitsubishi Cyborg 4WD-
Old 05-29-2009   #3
Constant_Project21
Drives: E36
I'm not positive, didn't get on it too hard, now I'm on a road trip..lol. So I'll check it again when I'm home. Almost positive it's the clutch though.
Old 05-29-2009   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah it definatly sounds like the clutch..
Old 05-29-2009   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
Do a pull in 5th. If it slips, it's done.
Start from a dead stop in 3rd, if it doesn't hook up, it's done.
Originally Posted by Trogdor
Old 05-29-2009   #6
Constant_Project21
Drives: E36
Thanks guys. Another question (may sound dumb) but my 16g didn't have a intake on it before, now it pulls 10 times harder. So does an intake explain my sudden boost in power? Seems dumb to ask, but it never pulled that hard before.
Old 05-29-2009   #7
cmspaz
Walls need hugs too
cmspaz's Avatar
Less turbulence = better and smoother airflow. I wouldn't be surprised, but I also wouldn't be surprised if it fixed something that was causing you to lose power.
Also, when do I get my boost leak tester back? I kinda need it.
Old 05-29-2009   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
If you are running a good amount of boost on the turbo, then the stock intake would become more of a restriction. So that could have been your case.
Old 05-30-2009   #9
Constant_Project21
Drives: E36
I'm running stock wastegate pressure. I must have some magical intake..lol
Old 05-30-2009   #10
Constant_Project21
Drives: E36
Sidenote-got on it a bit and didn't feel the clutch slip. Was driving it all night actually without a problem.
Old 05-30-2009   #11
blackrosenova400
blackrosenova400's Avatar
If you think your clutch is slipping, make sure you check your clutch adjustement before you condem your clutch. If it slave cylinder has pressure on the fork your pressure plate may not be clamping your friction plate fully.
Old 05-30-2009   #12
Constant_Project21
Drives: E36
Def didn't feel any slip when I was driving today, it pulled great all night. It may have just had a dsm moment there for a minute.
Old 05-30-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Haha. Well good to hear!
