Old 06-12-2009   #1
cmspaz
Walls need hugs too
cmspaz's Avatar
TMIC on a DSM? Crazy!
http://www.orldsm.com/forum/showthread.php?t=13236
If he's really seeing the temp gains he's claiming and getting boost as low as he's claiming, this could be huge. It won't stop me from getting an FMIC, but still, props to this guy.
Originally Posted by Trogdor
Old 06-12-2009   #2
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Re: TMIC on a DSM? Crazy!
Wow that's crazy! The piping is really short too.
Old 06-12-2009   #3
Cool that he's trying something a little different than the norm.
Old 06-12-2009   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
It's like a real shaker hood scoop.
I bet he has good response with that setup...
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-12-2009   #5
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Oooo I wanna do this. Would be sweet for a rally app, wouldn't have to worry about recking a front mount. That's a super short route intercooler. Can only imagine the response.
Old 06-12-2009   #6
I'd rather run no intercooler, meth injection and E85..
Old 06-12-2009   #7
^english racing style? lol
Old 06-12-2009   #8
Is that who did it? I know there is a 16g car running 30psi like that and holding 30 til redline. Screw the intercooler and let meth injection be the IC..
Old 06-12-2009   #9
Constant_Project21
Drives: E36
Yep that was english racing that did that, they ran low 10's with it. Was an automatic. Makes me want to find a cheap auto awd dsm and do that. Maybe throw some of those neat paddle shifters on there too.
Old 06-12-2009   #10
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Temp drop of 120F means jack shit. (unless he's talking about compared to other IC systems) Final temp, is what's important.
Old 06-12-2009   #11
Dude, the temps are 10 degrees below ambient too without any extra help. I also heard if he goes 88mph that it goes back in time.
Old 06-12-2009   #12
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
I'm skeptical of anything that allows air to enter the engine bay without passing through the radiator. DSMs have cooling problems enough as it is.
Old 06-12-2009   #13
123abc
123abc's Avatar
Drives: Loud cars
How do DSM's have more of a cooling issue than other cars?
Old 06-12-2009   #14
dumb_ricer
Hates Everything
Drives: Neon
They tend to make more power than other cars.
420A > LS1 > All Else
I > All else
Old 06-14-2009   #15
IDK, this looks like an awesome idea to me, it looks like an old guy is doing it too which more than likely gives him no reason to lie about how welll it does or doesn't perform like a younger person might do. It limits the size of intercooler sure, but it's original, very well done, and as far as we know it performs well. This guy has made a whole bunch of cool shit right in his garage too I think its pretty cool what he's doing
I don't get it, he moved the intercooler, the radiator didn't move....
EDIT: more info I found on the IAT's
Originally Posted by JAXWHITE1G on orlando DSM
As posted earlier I got some data on the efficency of my intercooler. I have done some Research Diving in the past and was trained to collect scientific data for study. But I was not tought to interpret it. I do know that the data collected is not good data. there were to many inconsistancies to be accurate. All were done on a long highway on ramp and posted speed was not exceeded. But traffic made it difficult to repeat experiments and the low speed ranges are passed by so quickly it was difficult to lock the temps at the right time to get good readings. I did learn one thing. I need a cold air intake system.
The first test was acceleration and highway cruise no boost.
outsid air temp 76 Deg
mph - inlet temp - outlet temp
20 - 131 - 91
30 - 135 - 97
40 - 135 - 95
50 - 144 - 93
60 - 147 - 93
70 - 161 - 100
15lbs boost
20 - 248 - 131
30 - xxx - xxx
40 - 262 - 138
50 - 257 - 134
60 - 302 - 159
70 - 331 - 174
These were averaged after several runs and I was so unhappy with the difficulty of getting acurate data that I forgot to test with the water sprayers on. I will do some testing again late at night when there is less traffic and I can get some more consistant data.
Also I was WRONG on the temp drop at idle. My data is collected in celcius and I have to convert to farenheit. My calculations were wrong the average temp is 10 above ambiant but will not go above that even idling for ten minutes.
I promised good or bad I would post the numbers so here they are. Tell me what you think!
Old 06-15-2009   #16
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
You're forcing air into the engine bay behind the radiator and increasing the overall air pressure in the engine bay. This means less air will be going through the radiator.
Old 06-15-2009   #17
I don't see how it could be much worse than putting a big FMIC right in front of the radiator though, Subaru's seem to do it without cooling issues, but then again I don't know much about aerodynamics either
Old 06-12-2009   #18
Closed deck cast iron blocks probably don't help either.
Old 06-12-2009   #19
123abc
123abc's Avatar
Drives: Loud cars
I'm just wondering because the only time I've had a problem with over-heating was when my fan relay took a dump. I wired it to a switch inside and it's been good since, with a fmic, and the stock oil cooler in the stock location. No a/c fan.
Old 06-12-2009   #20
This is a great idea. Only drawback I can see is that you are limited to a somewhat smaller intercooler. If I ever stumble upon a 1g and feel the need to make it into a race car I'd totally try this.
