Old 06-18-2009   #1
All my dsm,evo,mirage parts in 1 list FS/FT
JDM data plates
model: E-CD5A SNDF
chassis no. CD5A-0101523
engine: 4G93 ext: H84G
trans axle: W5M33 3545
color, int opt H84 29J 000
take 25.00 for them both
set of reflectors
here is a pic of them the outer tails and the center for the jdm plate does not come with them
40.00
set of evo I front recaro's they were in my car till I put in the evo III recaro's they are in the same shape I bought them in. the drivers set (right) has a hole worn into the sude easy fix I just never did it. the left seat is mint. they dont come with brackets I reused them for the evo 3 seats. 300.00 for the set of them.
oem p.p. 10.00
Exedy p.p. like a 2600 30.00
msd tach adaptor 35.00
auto meter 5" tach and shift light 100.00
auto meter red warring light new 30.00
evo III engine bay harness 75.00
evo III engine harness 125.00
evo III rs dash and body harness 100.00
act awd 6bolt flywheel 150.00
evo 9 rear wheel bearings 25.00 each
evo 9 rear knuckles 25.00 each
spyder parts and 2g/7bolt parts all spyder parts have 38k on them
tan leather rear upper seat 50.00
tan rear plastic panels 25.00 ea
tan door stills 10 ea
tan kick panels 5 ea
trunk lid with gas shocks purple 75.00
tan visors home link 10.00 set (could use a recover)
power steering lines 15.00
power steering cooler 15.00
clear front bumper lights 25.00
water pipe 15.00
oil filter housing no cooler on it 10.00
oil filter housing 20.00
rear block plate for timming cover 5.00
x2 power steering block brackets 10.00 ea
oil pick up 10.00
water pump to alt pully 10.00
alt heat sheild off the evo III 5.00
fuel filter and fuel line to rail 5.00
smic 20.00
black radio bez 15.00
heater core 20.00
fuel rail 20.00
x2 spyder top motors 50.00 ea
clock spring for the air bag and horn 5.00
air bag ecu 25.00
heat/a.c. controls 5.00
oil filter housing compleat 30.00
stock amp 15.00
eclipse tails outers 40.00
smic 30.00
x2 cams sets 20.00 set
fuel rail 20.00
x2 aculmator set ups 30.00 each
x2 crank sensors 10.00 each
1g parts and 6 bolt parts
intake mani bracket 5.00
clutch master 5.00
turbo water pipe 90 30.00
turbo water neck lower 10.00
n/a water neck lower 10.00
x2 water neck upper 10.00 ea
black w/red strip plug cover 5.00
front awd block mount lower 10.00
x2 rear awd block mount lower 10.00
x2 block timming belt filler panel 10.00 ea
x2 front upper block mount for power steering 10.00 ea
x5 upper block mount 10.00 ea
1ga back up and lic plate wiring and lights 5.00
90 awd shifter bracket for the tranny 10.00 ea
oil pick up 5.00
power steering bracket 5.00
clutch line rubber to slave 5.00
x2 water pump to alt pully 10.00 ea
x2 water pump to power steering pully 5.00 ea
x2 engine lift bracket for ext mani 5.00 ea
engine lift bracket for head to intake mani 5.00
power steering heat shield 5.00
x3 hydro tensioner 15.00 ea
horn 5.00
x5 tension arms 10.00 ea
x3 tension pully 5.00 ea
x3 idler pully 5.00 ea
x2 balance shaft pully 5.00 ea
oil pump gear for t.belt 15.00
x3 b.s. belt gear small ones 5.00 ea
x2 b.s. gear on the crank 5.00 ea
x3 main crank gear for t.belt 20.00 ea
x3 alt arms 5.00 ea
crank spacer plate for inbetween the crank gears 5.00
awd coolant over flow tank 5.00
cup holder 15.00
pwer reg drivers side 10.00
o2 housing 5.00
2din radio bez 5.00
1gb oem side lights 5.00 set
rear washer bottle no motor 5.00
green drivers door handle 10.00
white drivers door handle 10.00
x2 sets of red door handles 20.00 set
dip stick tube 10.00
battery tie down 5.00
90 fuel rail 20.00
wing never seen one like it it is urathane 40.00
tail lights 30.00
1 piston front brakes 30.00 set
moog tie rod ends 20.00 set
black and grey rear seat 20.00
black and grey front seats (will only trade for grey front seats)
power door panels 20.00 each
red gas door 10.00
red door handles 10.00 each
red power mirriors 10.00 each
black power mirriors 10.00 each
a-pillers 5.00 each
b-pillers 5.00 each
rear speaker panles 5.00 each
all trunk panels 5.00 each
good hatch struts 30.00 set
grey hatch cover not broken at all 40.00
5 speed tranny 4g63 n/t 75.00 (does not grind)
fly wheel 6bolt n/t 40.00
clutch 6bolt n/t 30.00
brake master 20.00
h4 headlight kit 50.00 (new bright phillips bulbs)
corner lights 5.00 each
turn sigle lights 10.00 each
center grill 10.00
injectors 4g63 n/t 40.00
x2 ign lock and keys 20.00 ea
door locks and trunk lock with keys 20.00 set
almost new hatch seal from mitsu 20.00
trunk and gas door cables and handles 10.00
red 1gb pass fender 20.00 needs some work not rusty
maroon 1gb pass fender 30.00
red 1gb drivers fender 30.00
1g intake manifold stock 10.00 have a few
4bolt rear end,axels,cups 225.00
also have other ramdom parts,bolts,ect just ask.
will also take trades on parts and multi parts that I have.
Old 06-18-2009   #2
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: All my dsm,evo,mirage parts in 1 list FS/FT
Happen to have the harness/plug that connects to the right front bumper/marker light?
Good 91 turbo ISC?
Old 06-18-2009   #3
I probley have the wiring and plug
I dont have any isc's right now
Old 06-19-2009   #4
turboimports
Can you check to see if you do....I need it. For whatever reason, mines is damaged.
Old 06-21-2009   #5
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Drivers side A-pillar and passenger side B-Pillar. Also, if you have them again, the bolts for mounting the trans on the block. Specifically the one that is by the pass. axle down below. Still can't get that shit figured. You should text me a price shipped for all that. 320 three zero five 0668
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 07-23-2009   #6
bump
trying to get new parts for the evo before the cook out
Old 07-23-2009   #7
GnArKiLl
GnArKiLl's Avatar
b-pillers 5.00 each... for the drivers b pillar plastic? if so ill take it
Old 07-23-2009   #8
I will see if I still have the b pillar for the drivers side
Old 07-23-2009   #9
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
1gb corner lights still available? Not the bulbs. Stock or clear? Have one clear one on right now, other got hit. Would like to have two matching. Would like to keep both corners matching. Let me know. Oh, and if you by any chance have a 1gb radiator fan, let me know also.
Thanks.
Old 07-23-2009   #10
I have one of the corner lights left and I do have some fans
Old 07-24-2009   #11
1slowdsm
1slowdsm's Avatar
Is the one corner light the stock one or clear one? I dont want mis-matching lights.
As for the fans, you just have the fans themselves of the whole thing?
Old 07-23-2009   #12
DSM_brother2
Drives: to the shop
do you happen to have the passanger quarter panel?
Old 07-23-2009   #13
I don't ever cut them off the cars and 90% of them are rusted out
Old 07-23-2009   #14
DSM_brother2
Drives: to the shop
darn, i really need one!! got a huge dent in mine thats not savable
Old 07-24-2009   #15
Its a oem light. I will have to see what side it is. It is the full fans
Old 07-25-2009   #16
GnArKiLl
GnArKiLl's Avatar
anything on that b pillar
Old 07-27-2009   #17
TSI2GSX
Still have the 97 eclipse visors? and just wondering if you have both front door panels??
TSI2GSX is offline   Reply With Quote
Old 07-27-2009   #18
Pm sent
Old 08-17-2009   #19
some new parts
clutch masters 2600 50.00
act fwd 6bolt fly 50.00
2ga head lights 20.00 set
1g crushed bov 30.00
2g grey hatch cover 20.00
1g grey hatch cover 20.00
x2 oem 2g fuel pumps 20.00 each
Old 08-23-2009   #20
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Hey Mark, would you happen to have a good bare 6 bolt head?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
