Old 07-04-2009   #1
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
No Reverse and bad noises...
So I start the car up to take it for a test drive. Put it in reverse, feels normal. Start slipping out the clutch and the car moves forward! All the other gears work great and engage good. However, there is also a rattling that has a metallic sound to it. It sounds kind of like scraping, doesn't matter if the clutch is in or out, what gear it's in, nothing. Shifter cables are hooked up right, nothing is loose. I even manually put the levers on the trans into the reverse position, and it does the same thing.
I also have a big oil leak on the oil pan, but that isn't as big of an issue as this. I would like to start daily-ing the car asap, but this shit is holding me back. Any and all input is welcome!
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 07-05-2009   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: No Reverse and bad noises...
The way the tranny shifts into reverse is kinda weird if a pin ar a detent ball came loose in the linkage it would probly shift into 5th instead of reverse.
I have a 90 FWD tranny sitting here if you need a different one.
11.35 @ 120mph
Old 07-05-2009   #3
123abc
123abc's Avatar
Drives: Loud cars
I sent you a pm regarding that trans.
If something broke in the linkages inside the trans, why would the car move forward when the levers on the outside physically go in reverse and every gear shifts like butter? On the outside, driving it, it feels just like it should.
Old 07-05-2009   #4
123abc
123abc's Avatar
Drives: Loud cars
I found something that might be of interest regarding the shifter cables:
Reverse:
5th Gear:
On those two gear it looks perfectly normal to me. Now, look when the top cable moves the gear selector down into the first and 2nd gear slot.
1st Gear:
See how the boot stays the same? Is that normal?
Old 07-05-2009   #5
123abc
123abc's Avatar
Drives: Loud cars
Reverse works now I guess. All I did was unhook the cables under the hood completely, only then could I manually put it in reverse under the hood. Hooked the cables back up and test drove it, all seems well now.
I'm going to swap turbos back to my 14b cause the 16g is junk shit. I'm hoping thats all my problem is. Otherwise it might be the starter too. Gotta drop the damn pan too.
Old 07-05-2009   #6
I took that turbo off my car for a reason, make a mut turbo or toss it, no other use for that turbo
Old 07-05-2009   #7
123abc
123abc's Avatar
Drives: Loud cars
Yeah, turbo's are already swapped. Oil pan is off too. Do they make thicker rubber or cork gaskets for the oil pan?
Old 07-05-2009   #8
Why not try rtv? That's how they came from the factory. I believe its grey rtv or something like that. I used high temp copper rtv on my friend's laser cause he got the wrong oil pan gasket and it doesn't leak at all. He even has 2 stripped out holes.
Old 07-05-2009   #9
123abc
123abc's Avatar
Drives: Loud cars
I tried that and it leaks. I used the black rtv shit, no gasket. I'd rather have some gasket in there tho.
Old 07-05-2009   #10
You gotta make sure the block and pan are perfectly clean if you're gonna RTV it. Black works the best.
Old 07-05-2009   #11
123abc
123abc's Avatar
Drives: Loud cars
I'll have to get a new tube, im just about out of my current black stuff.
Old 07-05-2009   #12
blackrosenova400
blackrosenova400's Avatar
I prefer Ultra Gray Rtv, always worked for me. Just make sure you have patience and let whatever you use dry for at leat 24 hours. Otherwise you will be pullin it again.
Old 07-05-2009   #13
123abc
123abc's Avatar
Drives: Loud cars
I think I did it wrong to begin with. I layed it on and tightened it up right away instead of letting it set for a half hour. Silly me.
Thanks for all the help guys.
Old 07-06-2009   #15
Just to make it a little more clear, put it on the pan or block, whichever works best for you, a thin layer will work fine as long as there are no breaks in it. Then install the pan right away, don't let it cure before you put it on. Then wait for it to fully cure before adding oil and running the engine.
Old 07-05-2009   #16
Yeah the key to rtv is to let it cure fully. I'm known as the rtv king between me and my friends. haha
Old 07-06-2009   #17
Use the light grey RTV and clean off ALL old gasket and make sure the surface of the oil pan that meets the block is perfectly flat. Get all of the oil off and make sre both surfaces are perfectly oil free and dry. use almost the entire tube or at least half of it and but the oil pan up with finger tightening the bolts on and go back an hour later and snug them but dont tighten the shit out of them.
Old 07-06-2009   #18
Don't let it skin over before you put it on, otherwise it won't seal to the other surface. well, unless you're a robot and can make a perfectly flat even seamless bead all the way around the pan. And like Kerry said, make sure the pan and block are absolutely clean. No old gasket material or oil on them.
Old 07-06-2009   #19
For the shifting problem, you might want to look at replacing the in-car shifter bushings. My car did the same thing, replaced the bushings and problem solved. Because the bushings were just so worn out, it didn't allow the linkage to get into reverse position.
Old 07-07-2009   #20
123abc
123abc's Avatar
Drives: Loud cars
I already have all solid bushings in the shift linkage. I got it fixed though, thanks.
Don't worry about it Brandon, thanks for trying to help.
I'm going to try the oil pan again on Wed. Hopefully I can get it to seal all the way around.
