Old 07-21-2009   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Drivetrain whirr on deceleration
I've heard this described as the "wub wub" sound, the whirring that happens on decel. It seems to be getting louder in my 1g.
I've heard that using some shims on the front or rear carrier bearing could help, to correct the driveshaft angle. Has anyone had success with this? Or is the problem that i've got a worn out rear end?
Style's automotive engineer
Old 07-22-2009   #2
Re: Drivetrain whirr on deceleration
If it sounds like it's coming from the back of the car it's probably your differential.
Old 07-23-2009   #3
s1ngletracker
Drives: A BMW
how can I tell for sure?
Old 07-23-2009   #4
SnoEclipse
Drives: 07 Eclipse GT
Post the specs of your car so peeps can make better educated guesses. Miles, lube history, etc, etc too.
It's hard to get under a moving car with a stethoscope to check every little thing.
SnoEclipse is offline   Reply With Quote
Old 07-23-2009   #5
s1ngletracker
Drives: A BMW
no kidding, thats why i'm a bit stumped.
93 talon tsi, 155k miles, bone stock, the Redline cocktail in the transmission, MT90 in the rear end (I think). Dont know a whole lot about the history as I just got it this spring.
Old 07-23-2009   #6
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
http://www.galantvr4.org/ubbthreads/...ev=#Post671739
The Galant VR4 guys had some success shimming their drive shaft to help eliminate the noise.
Old 07-23-2009   #7
s1ngletracker
Drives: A BMW
I have read that thread, thats what caused me to think about the shimming. I'm just not completely convinced that hat is the problem... and why would it need shimming in the first place? Because of motor mounts being worn out or something? I'm not convinced those guys REALLY know whats going on, they're just guessing.
Nevertheless, I will probably end up trying that.
Is this a common noise? Anyone here ever had it in a car? Ever fixed it? I'm really looking for personal experiences here.
Old 07-23-2009   #8
Another thing you can do is unbolt your driveshaft from the diff, and try to turn the input shaft. If you can turn it more than a few degrees before the wheels start to turn, it's worn out.
Old 07-23-2009   #9
CarRacer
CarRacer's Avatar
The shims are to compensate for the carrier bearings wearing out. Some people try the window weld fix instead which doesn't seem optimal to me. The shims are easily reversable.
I have the noise in my car. It's loudest on a third gear decel. It's not that high on my list of stuff to fix, so I've learned to ignore it. I will be addressing it though and plan to use shims to do so.
Old 07-24-2009   #10
s1ngletracker
Drives: A BMW
Cool, makes sense. I'm gonna give it a shot, i'll post my results.
Old 10-28-2009   #11
s1ngletracker
Drives: A BMW
shims didn't work. I tried about 4 different configurations, no dice.
