Old 08-12-2009   #1
4seasons69
4seasons69's Avatar
what turbo to get??
well I am officially in the market for a new turbo (new or used)
it's for my 1g talon and I'm looking for an EIII 16g or larger. but what I would like to know is what you guys recommend and what are some of you running and what kind of numbers are you making? thanks
Old 08-12-2009   #2
Re: what turbo to get??
evo3 16g
Old 08-12-2009   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
What hp do you want to put down?
Amsoil Dealer
Old 08-12-2009   #4
4seasons69
4seasons69's Avatar
I'd like to make 400whp at db on e85
Old 08-12-2009   #5
You would be darn close with my s16g and E85.
Old 08-12-2009   #6
You want my Super 16G trust me.
But seriously, if you want a turbo that will perform much like an EVO III with a little bit better topend power my Hahn super 16g would be the turbo to get. It won't put out quite the same power as your V-trim did, but they are much better turbos.
It comes with an adapter plate so the turbo will bolt up to your FP manifold, and comes with the O2 housing as well.
http://www.mitsustyle.com/forums/showthread.php?t=24021
The only thing you may need is a manifold spacer plate so it will clear the block and water pipe.
Old 08-12-2009   #7
4seasons69
4seasons69's Avatar
well I only made 30 hp more than you on the dyno dynamics so it's pretty close. but ill definitely think about it to get me back on the road.
Old 08-12-2009   #8
Evo 3 16g.
Old 08-12-2009   #9
evo III 16g
Old 08-12-2009   #10
I could sell you one of these
evo III 16 it is the one that came on my evo III front clip
pte scm5031e
frank 60-1
both of them are exturnal gated
Old 08-12-2009   #11
Forced Fed
Drives: FS-T
Forced Performance 16g, intended to run from 18-26 psi (doesn't mean you can't go higher).
Cost about twice as much as an MHI EVO III 16g but then again its 10 lbs of shit in a 5 lb bag.
Old 08-12-2009   #12
Stinger2G
Stinger2G's Avatar
Drives: 99 Eclipse Turbo Sold*99 subie Winter Baby
hey man go with the evo 3 16g or the fp 16g if you have got the money. i just bought much bigger turbo then the 16g so give me a call if you want my old evo 3 16g itz in perfect condition. i will give you the buddy discount lol
Stinger2G is offline   Reply With Quote
Old 08-12-2009   #13
4seasons69
4seasons69's Avatar
thanks for the input so far
Old 08-12-2009   #14
A 16G isn't going to put down 400awhp on my dyno without nitrous.
Old 08-12-2009   #15
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
how do u put nos on a turbo car
Old 08-12-2009   #16
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
The evo3 is poplular. It's for sure a solid choice in a street car. Mine certainly has put a smile on my face many times. Not sure bout the Hp # as I havent dynoed it, but it makes me happy. Take the advice ^ for sure though, he knows whats up.
I guess if your after higher numbers maybe step it up to 18g or a td06 20g. Those should get you up to the numbers your after, without being too expensive. Otherwise step it up to a ball bearing turbo like a scm50-60. Those will definitly put you in that range and above.
deadeye is offline   Reply With Quote
Old 08-12-2009   #17
I guess it's possible that a 16G car might, but it isn't likely. A handfull have gotten into the 350s-380s range, but I haven't had one hit 400 yet. Most put down in the 320-360 range on E85.
A 50-trim can hit 400awhp. 61s usually make over 400.
You usually run a wet nitrous kit on a turbo car. You can use a purely dry kit if you have a more advanced engine management system like an AEM EMS that can control the nitrous and add fuel through the injectors. You need to have enough octane to support boost and nitrous though, both use up octane. C3L1CA on here is running over 30psi and spraying nitrous on a stock internal motor with the help of E85.
If you don't have to make 400awhp though, the Evo 3 16G will give the best spoolup vs HP out of any turbo I know.
Old 08-12-2009   #18
john
Business as usual
john's Avatar
50/60 trim. I had a B16g about 8 years ago and got tired/accostomed to the power quite quickly. When I threw the 50 then 60 trim on, I was good for a bit longer.
I am sure some of the local 16g cars are fun but I think a little bit of lag is also fun. I would try to get a ride in a 16g car, then a bigger turbo car and see what you like better. Daily driving is also a different experience.
97 Viper GTS
Old 08-12-2009   #19
deadeye
deadeye's Avatar
^very true. I guess if its gonna be a dd maybe the 16g would be a better bet. If its a weekend warrior then go for broke.
Me personally (not that anyone cares), I like to do corners too, so a little less lag is good for that.
I do have to agree though, with a bigger turbo, the lag is pretty fun. Its kind of a tease, it makes you think, wow-this thing is kinda a pooch...then it builds boost and it pushes you back into the seat. Makes me feel like the power sort of snuck up on me or something.
Old 08-12-2009   #20
john
Business as usual
john's Avatar
^^^ Actually I liked the lag on a DD. Didn't have the turbo spooling all day long just before I shift.
97 Viper GTS
