Old 08-17-2009   #1
iceminion
iceminion's Avatar
Plug and Play Megasquirt for 2G.
This is fantastic news, one of the biggest drawbacks of megasquirt is that you have to create your own wiring harness or tap into the existing harness (messy)
Now, you can have all the Megasquirt goodness in an ecu that plugs right in, all for $460
Taken from the website:
OEM ECU Connector to plug right into the factory harness!
Speed Density, Alpha-N and Hybrid Alpha-N (both SD and A-N algorithms hybridized) Supported
2 Ignition Inputs (for dual wheel ignitions)
4 Spark Outputs (Up to 4 Cylinder Coil On Plug, up to 8 Cylinder Wasted Spark)
Rotary Ignition Support
Enhanced Acceleration Enrichment (EAE)
Boost Control
Knock Control
Launch Control
Flat Shift
Tachometer Output
Fully Adjustable Rev Limiter
Table Switching
4 General PurposeOutputs
4 General Purpose Inputs (2 analog, 2 digital)
Support for Flex Fuel
Optional Realtime Baro Correction
Closed Loop O2 Correction
Plenty of Proto Area, add your own customizations!
There's more than we could list here-- click this link to view the full featurelist of MS2/E.
http://www.diyautotune.com/catalog/d...kit-p-384.html
building a 3000GT AWD Turbo.
Old 08-17-2009   #2
iceminion
iceminion's Avatar
Re: Plug and Play Megasquirt for 2G.
Old 08-17-2009   #3
I have been kicking around the idea of MS for my Chevelle
Old 08-17-2009   #4
Nice! I've been using this on a local project car lately with pretty good success doing a pure alpha-n setup. (Birkin with a ztec motor with ITB's, not a dsm).
Old 08-17-2009   #5
that is nice. to bad they dont have a plug and play for a evo I-III
Old 08-18-2009   #6
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Anyone want to buy 2g dsmlink V3?
Old 08-18-2009   #7
That would be a downgrade.
Old 08-19-2009   #8
I agree! The dsmlink setup is the sweetest thing to happen to the DSM's since the 16g turbo. I just like that they are starting to introduce plug and play setups ,takes a lot of the install mistakes away.
Old 08-19-2009   #9
iceminion
iceminion's Avatar
Ecoli, I respect your expertise in DSMs, but how can you say Megasquirt is a downgrade?
Flexfuel (great for mixing E70/E85)
Direct COP
Direct injector control (not batch)
Speed density (wayyyyy superior to any "airflow meter")
Wideband controller talks directly with megasquirt, no "simulated narrowband output" needed
As soon as I saw the 2D timing tables on ECMLink, I put down the laptop and haven't looked at ECM link since.
Maybe I'm not giving ECMlink a fighting change, but seriously, side by side, Megasquirt outperforms ECMLink in every department
tons of room to prototype new technology on the ecu (look at the proto area)
Old 08-19-2009   #10
4seasons69
4seasons69's Avatar
Well, most of us know how to tune speed density tables (far superior IMHO), I think DSMLink will work for joesushi, but he needs to have it tuned....anyone up for the task?
I don't know if its out yet I don't frequent the link forums very much but they coming out with an update for v3 to run speed density
Old 08-19-2009   #11
Please explain to me how speed density is far superior to any airflow sensor and under what applications it is superior in.
...all due respect of course, I am all ears.
Old 08-20-2009   #12
Don't forget, this is the same guy who drills holes in engine blocks because his car has other issues he'd rather not address...
Old 08-20-2009   #13
Forced Fed
Drives: FS-T
Originally Posted by matt d. View Post
don't forget, this is the same guy who drills holes in engine blocks because his car has other issues he'd rather not address...
Epic Post!
Old 08-20-2009   #14
4seasons69
4seasons69's Avatar
ha ha ha ha
Old 08-19-2009   #15
I was mostly just being a snide asshole with that comment. I just can't see giving up one of the best ECUs and best knock control ever for a lowend standalone on a car that has good options for it already. Swap in an Evo ECU, if you want all kinds of cool stuff to play with.
DSM ecu's run injectors sequential, not batch.
DSMLink can do speed density, but a MAF setup is superior for most street cars. We convert 80s Mustangs away from speed density to MAF setups often.
DSM ECU's can't directly run COP, but the stock ignition is great in the first place. Direct COP is often not better than a coil pack wasted spark setup.
Wideband is not important with the stock ECU, stock O2 sensor or none at all works fine.
DSMLink can't do flexfuel easy, but the difference between E70 and E80(I don't normally see over 805) isn't huge for most cars.
Old 08-31-2009   #16
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
My Megasquirt is doing full sequential injection with 1150cc...
It could run COP but I have it using the stock coil pack...
Also my ECU isn't Eprom (which I guess there is a fix for that) but that was my push to use this system at the time.
IMO Megasquirt is catching on (not so much with the DSM unless it has a 420a motor) and it is rapidly advancing from what it was originally. It is becoming so much more user friendly with tuner studio
Just putting in my 2cents
I really don't think MS2 or MicroSquirt is a low end system anymore
Maybe the MS1 chip with a V2.2 board is low end but what they have now is much better.
Old 09-01-2009   #17
Tachyon
Tachyon's Avatar
Drives: Icarus
Good Luck running ITB's with your MAF
It's not. People are either confusing 'easier' with 'better' or are just plain inexperienced with the overall product. Now with MS3 just around the corner available as an add-in daughter board, we are really starting to compare apples to oranges. It's 2009... I choose control and flexibility with a vast and open ended user community. I choose MS.
-Sebastian Vettel
Old 08-20-2009   #18
jhaan_dude
jhaan_dude's Avatar
Drives: a car
hey hey hey!!! just because someone has a different take on the way to make a car perform doesnt mean we need to shoot him down! for all we know he may be onto the next great tune base for our loveable dsm! also everyone is entitled to their own opinion and i think that all should be heard!!!
Old 09-01-2009   #19
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
so u just plug it in and it automaticaly sets all your stuff or what
Old 09-01-2009   #20
I don't compeletely understand the question, but if you are asking if you just plug this box in and your car runs perfectly right out of the box without any user input at all, I'm going to go with no. You still need to open the program and set it up and modify it for your personal setup and plans you have in mind.
