Old 09-14-2009   #1
Powers
Powers's Avatar
Drives: 93 mx6!
Send a message via MSN to Powers Send a message via Skype™ to Powers
wont start
got the motor all in and the car will not start. there is fuel in the fuel rail and there is spark not sure if injectors are opening, so what else would cause it not to start and im sure there is a bunch of stuff. its a 95 talon tsi fwd plz help.
Powers is offline   Reply With Quote
Old 09-14-2009   #2
Re: wont start
what are peoples thoughts that this may be a CAS issue, but it has spark
Old 09-14-2009   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: wont start
Does the car reek of gas? Are you sure the spark timing is on and the cam timing is on?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-14-2009   #4
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
twack did all the timing so ask him and the car does not smell like gas at all
Old 09-14-2009   #5
Re: wont start
If it doesn't smell like gas after cranking it for a while, it's not getting fuel. Could be your MPI relay.
Old 09-14-2009   #6
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
where is the cas located and the mpi?
Old 09-14-2009   #7
Re: wont start
The CAS is on the corner of the valve cover.
Here's a link of where the CAS is with a pic. The MPI should be in your under the hood fuse box.
http://images.google.com/imgres?imgu...3Doff%26um%3D1
Old 09-14-2009   #8
Re: wont start
This is not correct... On 95-96 cars the CAS is located behind the intake cam gear.
If the CAS was bad the fuel pump would not turn on, let alone injectors wouldnt fire. On 2g's, there is no MPI fuse, there is a relay under the passenger side of the dash behind the kick panel that is along the center console but those rarely ever fail.
Sounds to me like a sensor is unplugged. Are you getting spark? Fuel in the cylinders? Good compression?
Old 09-14-2009   #9
Re: wont start
as far as te timing belt everything is lined up the fuel pump shoots fuel, but the injectors are not opening to deliver the fuel.
Old 09-14-2009   #10
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Re: wont start
What motor is it? 6 bolt or 7 bolt?
deadeye is offline   Reply With Quote
Old 09-14-2009   #11
Re: wont start
7 bolt
Old 09-14-2009   #12
deadeye
deadeye's Avatar
Re: wont start
7 bolts dont have a CAS. They got a cam position sensor thats under the timing cover.
If you guys did the timing, the cam position sensor could be to blame. If its the factory one, the wires are almost always toast and just looking at them wrong will make them snap and cause a real headache. Mostly cause you got to the pull the timing belt and maybe a cam gear to get at it. Rent a scanner from the parts store and see if a code pops up.
The wires for the crank sensor are the same way and would probably cause a no start too.
The other fussy bitch is the connector for the transistor pack. Make for sure that its completely plugged in. It actually takes a bit of elbow grease to make sure it clicks. The MAS can be the same way.
Old 09-14-2009   #13
deadeye
deadeye's Avatar
Re: wont start
^beat me too it by a second
Old 09-14-2009   #14
Re: wont start
BTW: CAS is AKA Cam Angle Sensor, so 7 bolts do have a CAS...
The Cam sensor controls the fuel pump and injectors...
The Crank sensor controls spark...
Find out what you're missing and go from there. As long as compression is good.
Old 09-14-2009   #15
deadeye
deadeye's Avatar
Re: wont start
I guess everything has a different name to everyone, but thats what mitchell1/alldata called it. I thought since it was detecting the cam gear and not the cam itself, it was a different animal. But who knows, its pretty much the same thing either way since its detecting the position of the cam to help apporpriate timing.
Maybe I should give up the sauce and I could get with it and figure out what stuff is supposed to be called.
In the end, it will make your car not run so check it out and see if its messed up. If you dont have a extra set of hands to see if your getting spark/fuel there should be a code for either the cam/crank sensors that will pop up on a code reader.
Old 09-14-2009   #16
Re: wont start
-yup has good compression across the board,
-he says there is spark.
-when you take off the fuel line and turn the key he says fuel sprays out so theres pressure in the rail, or at least it does the initial prime.
-at one point he tried pulling the injectors while still attached to the fuel line and turned it over. they did not spray. but if the pump was pressurizing the rail wouldnt the injectors pop out. so in my mind the fuel rail does the initial prime but then dost keep going. im just guessing.
so it seems like either a problem with the cas being broken or unplugged
Old 09-14-2009   #17
Re: wont start
An engine needs 3 things to run: Fuel, spark, and compression. Generally at the opertune moments help. Get a spark plug test or take a plug wire off and place it close to a good ground (not the fuel rail) and watch for spark. Then take a small screw driver or similar and hold it onto the injector, you should feel it pulsing while cranking. Check the CAPs in the ECU, check the power transistor, check the coils, check the coolant temp sensor, make sure the MAS is pluged in, check for thrust bearing wear, could have taken out the crank shaft sensor.
Old 09-15-2009   #18
123abc
123abc's Avatar
Drives: Loud cars
Re: wont start
Are any check engine lights on?
Old 09-15-2009   #19
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
yes the check engine light is on and i put a brand new cam position sensor in cuz i broke the old one taking it off
Old 09-15-2009   #20
123abc
123abc's Avatar
Drives: Loud cars
Re: wont start
Are you able to look up what code it is? Or maybe find someone who can?
