Old 10-08-2009   #1
Mike Neal!
Mike Neal!'s Avatar
Drives: 94 TSi, supermoto
When it rains it pours.. boom goes the 6bolt!
So DSM didnt fail me lol.. Ill let the pics speak for themselves.
I first noticed this hole in the front of the block.. and you can see through the oil pan!!
Then I saw what was left of the starter.. so something had to happen in the back too...
Oh hello!! there's another hole... and the attached piece of the starter..
I pulled the oil pan off and with it came the missing chunk of the block.
The team that caused the damage!!
Where is the rest of my piston???
When the rear of the block broke out, it broke the balance shaft which caused the gear to lock up and strip off the teeth on the timing belt.. whihc bent some valves... :l
So after all of that, Engine, Head and tranny (which something broke when the motor locked up cuz in gear it rolls like its on neutral) need to be replace.. When it rains it pours..
Mike Neal! is offline   Reply With Quote
Old 10-08-2009   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: When it rains it pours.. boom goes the 6bolt!
That's some real carnage there. Any idea what caused this?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 10-08-2009   #3
blackrosenova400
blackrosenova400's Avatar
Most likely the center diff blew out. Obviously the car didnt go that far so the rest of the transmission could possibly be ok, unless the center diff drive gear is stripped, then the counter shaft is toast.
Stock internals? How much power?
Old 10-08-2009   #4
Mike Neal!
Mike Neal!'s Avatar
Most likely the center diff blew out. Obviously the car didnt go that far so the rest of the transmission possibly could be ok.
If its in reverse it holds the car from rolling like it would if it were in a forward gear. It would be nice if the tranny was still ok but the way things have been looking im gonna assume its not so i cant be upset.. lol
stock internals. was supposed to be rebuilt(by previous owner).. so maybe poor assembly? didnt make much power or as much as I would think a scm6152e would make. compression tested low when I got the car.. 390awhp @ db. (shootout mode was 456.7awhp) was quick enough to beat my friends 05 cbr600rr with a passenger in my car tho!!!
Old 10-08-2009   #6
Mike Neal!
Mike Neal!'s Avatar
I can take a look at it for you if you wish.
Ill probably pull it apart and try and learn the tranny so I know for next time what to do.
thanks tho.. I may ask questions.
Old 10-08-2009   #7
4seasons69
4seasons69's Avatar
damn that sucks man!!!!!
Old 10-08-2009   #8
I don't see the problem here everything looks normal to me...
Old 10-08-2009   #9
Mike Neal!
Mike Neal!'s Avatar
Originally Posted by 123abc View Post
that's some real carnage there. Any idea what caused this?
dsm?!?!
Old 10-08-2009   #10
if it makes you feel better, that turbo on my old setup was 371 awhp on db's dyno on 111. 29x something on pump. low boost. Man, that was back when you had the stang still!
Old 10-08-2009   #11
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Holy carnage batman!
Old 10-08-2009   #12
Aww man that sucks. Awesome pics and good you got to beat up on a bike before it went kablewey. IMHO slap some JBWeld on there and see if it'll hold for a while.
Good luck with the rebuild, parts are common, so that's good.
Old 10-08-2009   #13
Just cuz you use JB weld on everything you have, including freezeplugs, doesn't mean it will fix his issues here!
Old 10-08-2009   #14
Kasey at MAP
Drives: E-85 '03 Evo
Send a message via AIM to Kasey at MAP
Wow hello balance shaft! Sorry for you Mike.
Kasey at MAP is offline   Reply With Quote
Old 10-08-2009   #15
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Ya, thats pretty solid destruction. Must have made some sweet sounds.
deadeye is offline   Reply With Quote
Old 10-08-2009   #16
Mike Neal!
Mike Neal!'s Avatar
lol actually it only sounded like my IC pipe blew off.
Dsm seems to be ok. I think this was cause by m ends with Ike. Silly noob blaming dsms, I've already heard someone accuse their car of crankwalking this week.
Hahaha.. okay.. sure..!!! the DSM comment was as a joke because everyone says DSM's break so that was my poke at them!! but if want a serious answer, because of everything that broke I dont know what the cause of all this was or where it started..
The piece of engine block that came off the front went through the radiator the piece in the back went through the starter lol.. the head is eff'd as well as the tranny(im gonna stick with it being broke that way if its not I have something to be excited about) lol..
Old 10-08-2009   #17
Old 10-08-2009   #18
Probably faulty engine assembly by prev owner. Mike is new to dsms, but he's not dumb.
Old 10-08-2009   #19
Mike Neal!
Mike Neal!'s Avatar
Thanks!!
Old 10-08-2009   #20
doesn't this make you miss the twin turbo stang mike?
