Old 11-06-2009   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Reverse Gear
I have a 1991 Eagle Talon Tsi AWD Turbo small 16G. Manuel Transmission ACT2600 clutch, short shifter( which might be the problem)
Description of problem:
A few weeks ago i bought a car. Long story short. After fixing a few things on it we tried backing it out the garage. Since we had to tow it home. The owner said it ran fine TRANNY WAS FINE! Well turns out that reverse gear is none existing. This might sound funny, but literally you can not get into reverse. Forcing it nothing, or trying to slowly shifting i had multiple people try it wouldn't go in. I contacted the previous owner. I am waiting for him to get back to me. In the mean time i would appreciate some suggestions. I think it is the short shifter i don't know what about the shifter linkage or bearings that could be wrong.
Drivetrain:
ACT 2600 Clutch Kit
Roller Skate Shifter Bearings
Non-Cruise Shifter Cable
For easy reference!
Thank You a head of time.
Old 11-06-2009   #2
Re: Reverse Gear
i know when i had a 1g, i would put it in first then reverse and it seemed to work, try that?
Old 11-06-2009   #3
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Reverse Gear
We tried that! From every angle you can possibly imagine. We let the transmission warm up thinking maybe the fluid could be the cause. No go.
Old 11-06-2009   #4
Re: Reverse Gear
you need to a just the shifter cables
Old 11-06-2009   #5
Re: Reverse Gear
Try moving it to reverse manually with the shift levers on the actual transmission. Also, make sure the shift levers aren't coming in contact with something such as a large intake pipe.
Old 11-06-2009   #6
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Reverse Gear
The shifter cables probaly need to be adjusted. Use two 10mm wrenches underneath your shift boot and adjust away.
'04 Honda Ricer: stock
Old 11-06-2009   #7
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Reverse Gear
Ok i guess i can give those suggestions a try. My question though if i can move it into reverse manually but not through the shifter inside the car what good will it do me?
Any more suggestions?
Old 11-06-2009   #8
Re: Reverse Gear
That right there tells me that the cables need adjusting. Also check for missing bushings in the entire shifter assembly. I had this problem once and it was as simple as that.
Old 11-06-2009   #9
Drives: 98 iVTEC
Re: Reverse Gear
Thats exactly why the linkage inside the car needs to be adjusted.
Old 11-06-2009   #10
Re: Reverse Gear
It'll tell you the cables need adjusting and/or there is something wrong with short-shifter.
Old 11-06-2009   #11
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Reverse Gear
Awesome i love this forum! I really appreciate it The only problem is i have never adjusted shifter cables...What should i make sure to not mess up. Or should i let someone with experience do it?
Old 11-06-2009   #12
Re: Reverse Gear
This site should help you will all sorts of stuff: http://www.vfaq.com/index-main.html
Old 11-06-2009   #13
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Reverse Gear
Ha i love goodharts quote!!! IT IS SO SO SO TRUE!!!!
Old 11-06-2009   #14
twack
It was a auto get over it
twack's Avatar
Re: Reverse Gear
haha my car wont go into 2nd 4th or reverse either. hmmm wonder what my problem is haha
