Old 11-19-2009   #1
Where to get timing belt tensioner tool
Not this:
http://www.amsperformance.com/cart/i...ioner_tool.jpg
But the tool used to twist the tensioner itself, it fits into the two holes:
I've used a few homemade ones, and while they got the job done, I'd like to find one that the pins don't bend on and you can actually fit a wrench on the nut once its twisted. I think MHI makes a tool for it, but I've heard other tools are out there. What do you use?
Name:	Screen shot 2009-11-19 at 9.22.26 AM.jpg
Old 11-19-2009   #2
Re: Where to get timing belt tensioner tool
I have one Chris, Ill let you borrow it if you need it. Otherwise Miller is the company that makes it. Also Jayracing sells a kit.
http://www.jayracing.com/index.php?m...index&cPath=17
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #3
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
That jayracing tool looks really nice!
Old 11-19-2009   #4
What is the miller one like? The jayracing one looks perfect, has anyone else used that? for $20, that fits the bill nicely (as long as it works good!).
Old 11-19-2009   #5
Here is the miller one. Same as the one I have.
http://cgi.ebay.com/ebaymotors/MITSU...motiveQ5fTools
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #6
Yummy, that one looks even nicer, no socket needed. Can you still fit a wrench on the bolt head ok with this tool? IT doesn't appear to have the notch cut out like the jayracing one does.
Old 11-19-2009   #7
I believe I bought mine from OTC tool in Owatonna.
Old 11-19-2009   #8
Constant_Project21
Constant_Project21's Avatar
Drives: E36
My buddy has a snap on one I believe. It's pretty awesome.
Old 11-19-2009   #9
^How do those compare to the ones blageo posted?
Old 11-19-2009   #10
I'm from Owatonna, you better buy from OTC!
Old 11-23-2009   #11
Well the OTC version has a hole in it to accept a 1/4" drive. I use a 1/4" to 3/8" adapter and an Dial Snap-on Inch pound torque wrench to set proper tension.
Realistically I've done 100+ 4g63/4g64 timing belts, not 1 failure. So I would imagine the part would be considered "good"
Chris,
If you want to just drive down and borrow mine, no worries. I just want it back in a timely fashion. It just depends if Savage is a good drive for you.
Old 11-19-2009   #12
Constant_Project21
Drives: E36
His is a stamped steel piece with the 2 prongs and a rubberized handle (no socket needed), I'd get a link but I'm on my iPhone.
Old 11-19-2009   #13
The Miller one has a radius on the bottom side(in the pic). you can fit a socket on the bolt easy. Honestly it works great.
Here is the OTC one. same as the miller one.
http://www.otctools.com/products/timing_belt_wrench
1998 Spyder AWD
567hp
490tq
Old 11-19-2009   #14
I used a ghetto version when I did my timing belt with just a 90 needle nose, and used the Jay racing style too. I really liked the jay racing style one because you can slide a socket over it or just use a wrench on it. All look like a good option though.
Old 11-19-2009   #15
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I have the OTC one... i believe i owe you a tool lending, let me know if you wanna borrow mine.
Style's automotive engineer
Old 11-19-2009   #16
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
I'd let you use mine but swifty has it (hint hint)
the one blageo posted is better, this lets you use a torque wrench to tighten the belt to factory spec rather than guessing, the snap-on/bluepoint one just has a handle sicking out the side
-David C.
Old 11-23-2009   #17
There is like a 2ft-lb torque needed on the belt tension while you torque the eccentric pulley. I like Blageos, as Dave said, because you can properly torque it.
Old 11-23-2009   #18
Thx dudes! I don't need one right now, I just figure for $20-30, I'll buy one to have handy whenever I need it.
Old 11-23-2009   #19
s1ngletracker
Drives: A BMW
I think the value of that tool is overstated. You can apply the proper amount of torque by just pushing on the eccentric pulley with your hand (though a bit more trial and error is required to do that)
Old 11-23-2009   #20
On a DSM, you could probably do it with a screwdriver if you had to, but on an evo, you really need one of these tools. The tensioner pulley spins the opposite direction on 7-bolts and it is (of course) an awkward spot to put a screwdriver, angled pliers, etc. It's one of those spots I usually end up doing and re-doing a few times to get the tension right and timing marks all lined up. Having the right tool should hopefully help
