Old 11-21-2009   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Bullseye V-trim oil feed?
Where is the proper location to put the oil feed line?
I am getting mix answers, from the head or from the oil filter housing?
Right now I am running from the oil filter housing but if this is too much pressure, is there a way of reducing the pressure?
Also anythoughts on this turbo?
I am not too fimilar with it but it is on my car. I am hoping for good results.
Old 11-21-2009   #2
Re: Bullseye V-trim oil feed?
a restrictor is a way to reduce the pressure, but the best way would be to measure it right before the turbo.
Assuming this is a JB turbo I would say a OFH with BS would be fine without BS might be a bit high.
Old 11-21-2009   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Agreed. It isn't ball bearing right?
Amsoil Dealer
Old 11-22-2009   #4
Andrew7dg
Andrew7dg's Avatar
The Balance Shafts are removed and the oil pressure is higher then stock.
This isn't a BB turbo however after doing more research it appears that this jb turbo doesn't like the High oil pressure off of the oil filter housing.
SO...i have a problem then of too much oil pressure going to the turbo
How do I measure the pressure going to the turbo?
How much pressure do I want going to the turbo?
What is the best restrictor to use to lower the pressure? (the oil feed from the head is already blocked...) Is there a home depot solution for this?
BTW info for this V-trim, it looks like a picky turbo and likes to surge so I will post up on how this performs
Old 11-22-2009   #5
Find a Tee to put a gauge, from what I have read (I was trying to find this again to double check, maybe someone on here knows) but oil psi is dependent on RPMs not load, so you can get a T and a gauge and have someone rev your car while you watch oil psi. I would say no less than 10psi at idle and no more than 70-80, but best bet would be to call SB/Bullseye tomorrow and ask them about the specs.
Old 11-22-2009   #6
4seasons69
4seasons69's Avatar
I was running this turbo for a while and it surged in lower boost but smoothed out as boost built. I was running a 25psi spike settling to 21.
I also talked to the head turbo guy at bullseye and he told me to not run a restrictor with my v-trim but I still have my balance shaft so it might be a good idea to just call them and see what they say
Old 11-22-2009   #7
jhaan_dude
jhaan_dude's Avatar
Drives: a car
contact garrett, they will be able to give you the specs on how much of a restrictor you need.
Old 11-23-2009   #8
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Bullseye doesn't make their center section...so call garrett.
Old 11-23-2009   #9
95talonracer
Finally Tuned...
Drives: Spyder GSX
run it off of the head without a restrictor. Thats what I do except I do have a restrictor because of mine being BB.
Amsoil Dealer
Old 11-23-2009   #10
Andrew7dg
Andrew7dg's Avatar
I may have a problem running the oil feed off of the head right now because it was blocked off a while ago (kicking my self right now). And it may be a permanent block off till I get my rebuilt cylinder head on there (which may be a while)
I called bullseye and he mentioned that the restriction is really just a band aid and he didn't recommend using one. He mentioned to just check the pressure and it should be somewhere between 60-80 psi if higher use a restriction.
Does 60-80 psi sound right for an oil pressure? How about with BS removed? I really don't know what these cars run and all I have used is that dummy gauge?
I found a compressor map for this and I will post it later with an analysis.
Old 11-23-2009   #11
4seasons69
4seasons69's Avatar
60-80 should be normal in the higher rpms. with bs removed it could be higher. I know some people have seen 120psi on a cold start and dropping as the engine warms up
Old 11-23-2009   #12
Do u at least have a oil psi gauge for the motor?
Old 11-24-2009   #13
4seasons69
4seasons69's Avatar
good ? or do you at least have a diagnostic oil pressure gauge you can plug in to where your oil sending unit does to see what your oil pressure is??
Old 11-25-2009   #14
Andrew7dg
Andrew7dg's Avatar
I think I have a gauge sitting around here that I could hook up to the engine. I don't know the accuracy of an auto meter but we can hook it up to see whats going on.
Should I hook this to the engine first or should I make a T fitting by the turbo to see what the pressure is?
Or should I just buy another separate gauge?
