Old 12-14-2009   #1
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Part out- 92 Laser RS AWD
Speed density harness, GM 3 bar map sensor, GM IAT- $100
Thanks
Nick~
Give me a call if you have further questions.
651-270-4132
Old 12-14-2009   #2
Re: Part out- 92 Laser RS AWD
U will still be slower than me!!
lol.
I have a munchgsx motor with 165k and I'm driving it 14hrs home on friday, these things last and we all know they can make power.
Old 12-14-2009   #3
Munch motors ftmfw, very nicely put together motors.
Good luck with the part out!
Old 12-14-2009   #4
Constant_Project21
Constant_Project21's Avatar
Drives: E36
How much for the shell?
Old 12-14-2009   #5
munchgsx
munchgsx's Avatar
Not sure how to price the shell. If you want it I would say take some time to come see it in person. Then we'll talk numbers.
Old 12-14-2009   #6
Constant_Project21
Drives: E36
I'm in for some pictures. Idk when I'll be able to check it out, but have been thinking of getting a shell after I sell mine.
Old 12-14-2009   #7
munchgsx
munchgsx's Avatar
I'll take some shots tomorrow. The shell will need paint but it is rust free. Also note that it is disassembled for paint but is complete. I also shaved the wiper and antenna and also the washer nossle. I did not cut corners on the metal work it's all done correct and ready for bodywork/paint. It did have rust in the normal DSM spots that I repaired by cutting all rust out and welding new steel in.
Old 12-14-2009   #8
Constant_Project21
Drives: E36
Sounds good. What was the original color?
Old 12-15-2009   #9
munchgsx
munchgsx's Avatar
Black
Old 12-14-2009   #10
What bov is the piping flanged for on the SBR kit? Can you send me some pics?
Old 12-14-2009   #11
munchgsx
munchgsx's Avatar
1G , I'm posting pictures tomorrow
Old 12-14-2009   #12
Does it include everything needed to bolt on and in good condition?
Old 12-15-2009   #13
munchgsx
munchgsx's Avatar
Yes, the condition is good but used.
Old 12-15-2009   #14
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Pictures!
Old 12-15-2009   #15
More info on the short block please
Old 12-15-2009   #16
Get some pics up!
Old 12-16-2009   #17
munchgsx
munchgsx's Avatar
Bored .020 over with 2G pistons and 1g Rods, balance shafts removed, all arp hardware including rod and main bolts, new main and rod bearings (ACL), ported oil pump because the block has no squirters. Had 175 180 accross before I took it apart.
Get some pics up!
Some pictures are up!
Old 12-16-2009   #18
munchgsx
munchgsx's Avatar
The red door is jamed. The original was beyond repair.
Old 12-16-2009   #19
turboimports
How does the FMIC fit with the front bumper on? FMIC fill the the main bumper opening?
Assuming those are stock fog lights? Fit stock fog lights?
Old 12-16-2009   #20
munchgsx
munchgsx's Avatar
It does fill the front and will work with stock fog lights. I did trim the bumper a bit because Lasers have a billion vents that stick back 4". It wasn't needed to reinstall the bumper. I geuss it's all in the way you mount it.
