Old 12-28-2009   #1
Powers
Powers's Avatar
Drives: 93 mx6!
Send a message via MSN to Powers Send a message via Skype™ to Powers
Help!!!
ok so i was on the highway and i watched my oil pressure gauge drop and the motor sputtered and died. it still cranks over and everything but wont start there was a wire unhooked from the oil filter housing not sure where it connects to but any ideas please let me know im guessing bent valves?
Powers is offline   Reply With Quote
Old 12-28-2009   #2
Re: Help!!!
If the motor dies so will your oil pressure. Check for fuel and spark, do a compression test, etc.
Old 12-28-2009   #3
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
lost oil pressure and drove off the highway so like 3 mins of no oil pressure before it died
Old 12-28-2009   #4
Re: Help!!!
No oil press will toast the bottom end really fast
Old 12-28-2009   #5
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
planned on doin a comp test tonight but i cant find my comp tester so gotta wait till tomorrow
Old 12-28-2009   #6
Re: Help!!!
You lost oil pressure and continued driving for 3 mins? When oil pressure drops you need to shut off the engine immediately if you want any chance of it surviving.
Old 12-28-2009   #7
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: Help!!!
If the wire that goes to the filter housing, is the one that actually reads oil pressure, then it will say it doesn't have any if not connected....could be a coincidence that it won't start, or your motor could be toast.
Old 12-28-2009   #8
Re: Help!!!
Originally Posted by alliance14 View Post
there was a wire unhooked from the oil filter housing guessing bent valves?
unless this constantly happens and you dont believe in the stocker at all.
Old 12-28-2009   #9
Re: Help!!!
Yup, especially if it gets oily, that little wire can even be hooked up and not get a solid reading up to the factory gauge.
Old 12-28-2009   #10
Re: Help!!!
I assumed you were using an aftermarket gauge. The stock gauge is pretty much worthless, the low oil pressure warning light is generally pretty trusty though.
Old 12-28-2009   #11
Re: Help!!!
last i saw the car it didnt have an aftermarket gauge
Old 12-28-2009   #12
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
its a stock gauge and the gauge always bounced around and was never accurate so i didnt really pay attention to it when it just dropped completely but then the actual oil light came on then it crapped out.
Old 12-29-2009   #13
Re: Help!!!
I don't know what you're expecting us to tell you. You KNEW there was a problem with the car, no oil pressure, yet you continued to drive it. Good luck.
Old 12-29-2009   #14
Re: Help!!!
Tough love mattd, tough love. Let us know how the compression/leakdown tests go.
Old 12-29-2009   #15
viridionplague
Re: Help!!!
im inclined to agree with matt here, just assuming its a faulty guage is a bad idea, cause what if your wrong? and in this case it appears you were.
although i do with you the best of luck in getting whatever the issue bmay be resolved
Old 12-29-2009   #16
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
the best way for me to describe how it died would be the exact noise a car makes when your trying to teach someone how to drive a stick and they just pop the clutch and it dies it still turns over and everything nothing is knocking or clicking when it turns over
Old 12-29-2009   #17
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
i really didnt know cuz the gauge was effed up so i really didnt know it was a problem i just assumed the gauge was acting up so i just need to get some aftermarket gauges after its fixed
Old 12-29-2009   #18
Re: Help!!!
Uhh, yeah... If you drove for 3 mins with the oil light on, your bottom end is toast. Any loud rattling, clanging or banging when the motor sputtered out and died?
Old 12-29-2009   #19
Constant_Project21
Drives: E36
Re: Help!!!
Do your cam gears move when turning it over?
