Old 12-31-2009   #1
To cut, or not to cut?
I did a photoshop of my bumper uncut and cut. I'm not sure on what to do.. If I cut it, I will get more flow to the radiator and eliminate the possibity of over heating. But it looks cleaner without it cut. What do you guys think?
UN-CUT:
CUT:
Clean look or mean look?
Old 12-31-2009   #2
Re: To cut, or not to cut?
A cut bumper can look very clean and aggressive IF cut properly, smoothed, then painted.
Old 12-31-2009   #3
I just picked up a bumper from GREASEMONKEY and I would be cutting it just like the photoshop. Then after having it cut, it would be painted. I cut my old bumper and it was pretty clean.
Old 12-31-2009   #4
Forced Fed
Drives: FS-T
Un-cut looks better but cut is gonna be better performance wise, so I would recommend cut.
Edit- Get rid of those fog lights while you are at it.
Old 12-31-2009   #5
I just made a bracket for them last night to keep them haha. They're the main light for my car since my headlights don't pop up. Plus I think it just looks too plain without them.
Old 01-01-2010   #6
Constant_Project21
Constant_Project21's Avatar
Drives: E36
NO WAY!!!!! There's nothing better looking than a fully filled bumper imho. I think that looks awesome.
Old 12-31-2009   #7
Constant_Project21
Drives: E36
I usually don't like the cut look, but that looks mean if that's what it will look like. I'd go with cut.
Old 12-31-2009   #8
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
I'm not sure the extra surface area is going to solve all your problems. I would start by making sure that all of the air coming in the front cant go anywhere but through the radiator by blocking areas where airflow can go around the IC and radiator. Then maybe vent the hood if you still have cooling issues.
Also your headlight intake probably isn't helping in the cooling department. By letting that air into the engine bay it's increasing the overall air pressure resulting in less air thru the front of the car.
So I would say uncut. Because if you are overheating, I don't think that will fix it.
Old 12-31-2009   #9
Another option, one that I've been looking into, is holes. NOT circle holes, as those look tacky, but ones sorta like this:
You can also use really small vaccuum line, split it the long way, and then use it as trim once the hole, or bumper has been cut.
Old 12-31-2009   #10
Forced Fed
Drives: FS-T
Oooh, Thanks swifty, that reminds me of what I always planned on doing... Put about 5 circular cut outs to get more air-flow but this looks nice too.
Old 01-01-2010   #11
sorry swifty but i think it looks like a hitler mustache. The only problem i have with cut is that you better do a damn good cuttting job ive seen to many hack jobs, and i also worry about if the plastic will sag and distort over time. If it does that then it never looks good. Maybe make some good bracing for all of it so it can hold its shape
Old 01-01-2010   #12
There is no way I will be cutting holes in the front like that. I just don't like that look at all, although it would be very benificial. I'm leaning towards uncut right now. I wouldn't say I'm having cooling issues though. Once I removed the stock fan and put on this slim fan my coolant temps have been a bit higher than before. I guess I'll just have to add another fan!
Oh, and I did do the split vacuum line trick on the cut-out on my old bumper.
Old 01-01-2010   #13
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Cutting mine hellped alot with cooling and intercooler efficency. I cut mine with rounded off corners for a little cleaner look IMO.
ID:	9551   Click image for larger version
11.35 @ 120mph
Old 01-01-2010   #14
Yea I remember seeing your car at the cookout. The only thing is, is that your front mount is about twice the size as mine haha. I am running the SBR 8" street kit. I was pondering the idea of trimming the under-part of the bumper. So it would leave a gap between the bumper and intercooler for air to get up and through.
Old 01-01-2010   #15
jrohner
jrohner's Avatar
When I've seen your car, I've always liked the look of it EXCEPT for the cut bumper. An uncut one will improve the look of your car quite a bit.
Old 01-01-2010   #16
Thanks! Yeah the cut-out I did didn't turn out as well as I wanted since the bumper started to warp on me..
Here is the plan as of now. I marked where I'm going to cut the bumper in red. It's just to give the air some room to go up and over the intercooler.
Old 01-01-2010   #17
Uncut
Old 01-01-2010   #18
I wouldn't cut it, your car looks mighty clean with it un-cut. I can see cutting it like you have outlined it red though, as long as you can't really see it.
Old 01-01-2010   #19
You won't be able to see that cut at all. It would look like a stock bumper. Unless you bent down and looked up.
Old 01-01-2010   #20
311evo
311evo's Avatar
Cut it.
Swifty, that looks like garbage. Don't do it.
