Old 01-07-2010   #1
CBRD BBK-B aka BBK-XL turbo
Alright, enough talk about FP products! It's time for some blue billet fun. CBRD has been working on a slightly bigger compressor wheel for the BBK, and they're calling it the BBK-B. Apparently it is still SMALLER than a FP Red, but the numbers sure look promising.
GST has a customer car they've been testing out a BETA version of this on, it is a cast version of the wheel, and chad said the final version will be billet and also mentioned that it will be slightly larger still. Actual airflow rates are not out yet, but I'm *guessing* it'll be near their EvoX turbo @ 57lbs/min. FWIW, the original BBK is rated at only 47lbs/min, yet seems to put out numbers shockingly close to FP Red setups (from what I've seen locally) with better bottom-end and a little more drop-off on the top-end (after peak whp).
Like the FP Red and Black, both the BBK and BBK-B share the same turbine wheel, making upgrading for existing customers very cost effective.
Now, let's look at some numbers. This is GST's Mustang dyno, it seems to read nice and conservative, similar to our local heartbreaker dynos. Remember, this turbo is still 100% STOCK APPEARING, stock WGA, stock compressor cover, etc. Once an intake is strapped on, its incognito
Here's the test car with a standard BBK. Note that it's a 2.3L so torque is a little insane, esp since its on E85. The lower graph is the exact same setup, on the stock 2.0L. 442whp/410wtq@30psi on the 2.0L (not far off from my car) and then 458whp/460wtq on the 2.3L.
Mods (this is a cali car, so it has a LOT of stock stuff on it, including the stock intake snorkel!):
GST 2.3L stroker
Oversized valves in head (no head porting)
3" Downpipe
3" Agency Power catback
RRE rally cat (resonated test pipe)
Titek V2 tubular 02 housing
Ported stock exhaust manifold
CBRD BBK Full XL Beta (ported)
GST open cone air filter
Perrin FMIC
AMS LICP
Stock BOV
Cosworth M2 mivec cams
FIC "BlueMax" 1250cc injectors
AEM fuel Rail
AMS fuel return line
Denso IKH24 spark plugs (1 heat range colder)
GM 3 port boost solenoid using ECU-controlled boost
Stock ECU (Tephra V7 ROM)
Stock MAF
Stock Intake Manifold
Stock Upper IC pipes
E85
Then, the BBK was swapped out for the BBK-B Beta:
476whp/464wtq. Note the minor loss in spool-up and the basically +20wtq from 5000rpm up. Very little lost for a fair amount gained!
At this point, the car was out of fuel, so a few things were added:
-synapse BOV
-FIC 1550 injectors
-BlaqOps Double fuel pump setup
Here's where the car is at today, still on the BETA wheel. 502whp/481wtq@32psi, tapering to 28:
net gain, +44whp/+21wtq, and about 100-150rpm loss in spool-up.
Now, time for speculation:
I'm super curious how this turbo will perform on pump gas. BBK Full did a best of 388whp on my car at only 25psi, will this BBK-B be good for closer to 400? Time will tell! Chad said the compressor wheels are still a ways out, so maybe late february we'll see some more actual numbers out of the final version.
Old 01-07-2010   #2
Re: CBRD BBK-B aka BBK-XL turbo
So when do you get yours?
-where did the little raising eyebrow smiley go?
Old 01-07-2010   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I hate you evo guys and your crazy ability to make easy hp..hahaha. That 2.3l sounds like a crazy fun car, and with it still just in the beta phase, I can't wait to see what the actual production turbo puts out. Keep us posted scheides!
Old 01-07-2010   #4
mlomker
*Resting In Peace*
mlomker's Avatar
Not sure that I'd call a stroker kit that's in the neighborhood of $5k just for parts an easy upgrade.
Old 01-07-2010   #5
Constant_Project21
Drives: E36
Evos in general, never once said in that post anything about the 2.3l project being easy hp. I realize that's a bit of work, and money, I'm not a ruh-tard.
Old 01-07-2010   #6
mlomker
*Resting In Peace*
mlomker's Avatar
Evos in general
Nobody would pay what they cost, otherwise. We'll have to see what happens with E85 on a 2 liter.
Old 01-07-2010   #7
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
I would. I can't believe how many people buy these to make big power. The handling is mind blowing, and I think the factory output is enough to make good use of it.
Old 01-07-2010   #8
Evos truely are a ton of fun stock, or nearly stock. I still think of my car as mostly stock, let me know if you wanna drive it sometime. Regardless, I picked up one of these for you, let me know when you need it.
Old 01-07-2010   #9
LOL you think of me as a super model too or what?
Old 01-07-2010   #10
Weird, I think the same of mine too. Few basic bolt-ons, right?
Old 01-07-2010   #11
That is all I have.
I think EVOs are awesome esp. since the price is coming down now, If I were starting again say with DSMs I would probably say F it and go evo with all the handling Advantages it has.
Strokers for evos can use good ol' DSM 7 bolts, there is a few guys on link forums running them and one with a 2.4 + mivec = F'n hotness, picked up 100WHP.
ANywho, scheides when you get one of these.
Old 01-14-2010   #12
More prelimary data, through the grapevine:
http://forums.evolutionm.net/evo-dyn...ml#post7886606
Originally Posted by CBRD
the highest BBK on our dyno on pump was 427whp, BBK-B test bed on pump was 439whp same car hotter weather less boost, and calebs evo ix with BBK-B stock cams, stock uicp, perrin intake, turboback, fmic and tune made 397whp on pump
397whp on stock IX cams on pump! Holy eff! I can't wait to see these plots.
Old 06-28-2010   #13
Pricing announced! $1750 including porting. BBK owners can upgrade for $599
Old 06-30-2010   #14
Originally Posted by CBRD View Post
here are some plots,
28-29 psi on 93,
This car is WAY WAY out of injector up top, you will be able to see where it goes lean around 6600 and then knocks and retards the timing.....
I have 1000cc coming for all three of these cars (all were on 780s) that we are testing this week.
Here is the plot of two pulls, I have also incuded the raw data for boost afr and tq and hp so you can see where it hits those boost levels and the coorelated numbers.
Cheers
CB
Old 06-30-2010   #15
780s (boo)
Old 06-30-2010   #16
^Your 850's would support this turbo just fine dizzle
Old 06-30-2010   #17
I know! Who needs E85?
Old 06-30-2010   #18
^Not u mighty dizzle
Old 06-30-2010   #19
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
I see this on my evo in the future if there isn't too much lag over the stock 9, Looks like this is 300 rpm later than the full, on a car w/ cams.
Old 07-02-2010   #20
