Old 01-15-2010   #1
Chim55117
Drives: 2007 BMW 335i Coupe
4G63/4 Rod and Piston Differences
Quick question, are I think the 4G63/4 pistons are interchangeable, but are the 4G63/4 rods? Or are the rods different lengths. Will I need 4G64 specific rods?
Thanks in advance,
- Stephen
Chim55117 is offline   Reply With Quote
Old 01-15-2010   #2
Re: 4G63/4 Rod and Piston Differences
Rods are the same, pistons are not.
Old 01-15-2010   #3
Chim55117
What are the differences with the pistons?
Old 01-15-2010   #4
For one thing the 64 is a bigger bore, so the piston is bigger.
Old 01-15-2010   #5
Chim55117
So 1G 6 bolt rods from my extra 4G63 block will work just fine?
Old 01-15-2010   #6
Rods are the same...
Old 01-15-2010   #7
Chim55117
Sorry guys. I wasn't paying attention. I'm slipping in and out of typing and pretending to work.
Old 01-15-2010   #8
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I will explain...
The pistons from your 4g63 will not work because the bore of the 4g63 and the 4g64 are different.
4g63 85mm
4g64 86.5mm
So no... the 4g63 will just slap around in there
You will have to buy aftermarket pistons for the 4g64 if you want to do the hybrid combo
If you want to do the stroker combo (4g63 block/ 4g64 crank) you will have to buy aftermarket pistons as well
but what are you trying to do is the question...
Old 01-15-2010   #9
Chim55117
Originally Posted by Andrew7dg View Post
I will explain...
4g63 85mm
4g64 86.5mm
4G64 block, stock 4G64 crank, 2G rods, not sure on the pistons yet.
Old 01-15-2010   #10
Andrew7dg
Andrew7dg's Avatar
Also you might as well go with aftermarket rods. Otherwise you will have to machine the 7 bolt rods for aftermarket pistons (which would cost you and won't hold as much power as aftermarket)
IMO anyway
Old 01-15-2010   #11
Andrew7dg
Andrew7dg's Avatar
Is it a 7 bolt 4g64?
I usually deal with just the 6 bolts
If it is just a stock 7bolt 4g64 can't you just slap a 4g63 DOHC cylinder head and be done with it? (granted the pistons wouldn't be as strong and other stuff but it would get you by)
Old 01-15-2010   #12
you have to put pistons on a 7bolt 2.4 they were sohc motors from spyder's and galant's. It would be the same bottom end that I will be putting in the evo.
I am using ross 2.4 dohc pistons and eagle 2.0 rods in it
