Old 01-19-2010   #1
93tsiawd
Drives: 90 gst
WTB: 1g dsm parts
lookn for parts for my 90 tsi awd project, lookn for a awd driveshaft, engine cradle, awd tranny, ecu has to be out of a 90 tsi awd or gsx awd, fmic kit, some upgraded injectors 550-650cc, real 16g turbo, walbro 255 fuel pump, aftermarket full exhaust, lowering springs, n a **** ton of interior. lmk what ya got
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 01-19-2010   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: WTB: 1g dsm parts
Have a real mhi small 16g for sale in the for sale section.
Old 01-19-2010   #3
I've got the AWD tranny, it's a 91 though.
Old 01-19-2010   #4
93tsiawd
Drives: 90 gst
oh would that 91 tranny still work for my 90?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-19-2010   #5
iceminion
iceminion's Avatar
no, the 90 transmission, transfer case and shifter cables are specific to that year.
I would suggest converting your car to 91+, its cheap, and easy and you don't have to deal with the 90 BS anymore, thats what shep says too.
building a 3000GT AWD Turbo.
Old 01-19-2010   #6
93tsiawd
Drives: 90 gst
what do i all have to do?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-20-2010   #7
Install a shifter assembly and shifter cables from a 91-94
Old 01-20-2010   #8
93tsiawd
Drives: 90 gst
aight anybody know where i can get a shifter assembly n shifter cables?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-20-2010   #9
acidrumz
I have the driveshaft, the two rubber support bearings have been replaced new with oem parts. I also have the shifter assembly and shifter cables too. They both are from 91+ dsm. LMK...
acidrumz is offline   Reply With Quote
Old 01-20-2010   #10
93tsiawd
Drives: 90 gst
can i use the driveshaft on my 90 even tho its off a 91+?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-20-2010   #11
acidrumz
iirc, you will need a 91+ tranny/transfer case to mate with the 91+ driveshaft because of the spline count of the tc.
Old 01-20-2010   #12
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Im pretty sure that the spline count on the driveshafts are all the same 90 - 94.
If you have a 1990 Tranny & X-Case and you want to switch over to a 91+ setup you will need to change your tranny and X-case but the driveshafts are the same 90-94.
I dont know if i misread your post or not but hopefully that clears up the confusion.
-Stephan
Old 01-20-2010   #13
acidrumz
-Stephan
ok it must have been just the tc that has the different spline counts per 90/91+
thanks for clarification, so to the op, yes the driveshaft would fit.
Old 01-21-2010   #14
Wizard
To use a 91-94 trans in your 90 you can do one of 2 things:
(1)swap the cables, and shifter assembly
(2)swap out the bracket on the transmission
89-90 T-cases are 22 spline input whereas 91+ are 23-spline. The outshafts of all T-cases are 21-spline (in other words the propshafts will interchange) Most driveshafts will fit into any 1g trans, awd/fwd/AT/MT doesn't matter.
To use a different t-case (ie, 22 T-case to 23 spline trans) you can simply swap out the output shaft from the transmission. Literally takes 15-20 mintues and doesn't require transmission removal. In other words, running a 91+ trans (23-spline) with a 90 T case (22 spline) just aquire a 22-spline output shaft (I keep 1 of each just for that reason)
Wiz
Old 01-21-2010   #15
93tsiawd
Drives: 90 gst
aight..i found a tranny..i just need a t case now..anyone got one?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-21-2010   #16
Wizard
Do you have any t-cases?
Wiz
Old 01-21-2010   #17
93tsiawd
Drives: 90 gst
no thats y im looking for one lol
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-22-2010   #18
Wizard
Ok, I'm no help though since I only have 2 AT T-cases.
Wiz
Old 01-23-2010   #19
GREASEMONKEY
Drives: 92 TSi
I have a 22 spline and a 23 spline x-case if your interested.. PM me if your interested
-Stephan
Old 01-26-2010   #20
93tsiawd
Drives: 90 gst
well im using a stock original 91 tranny n not sure if its 22 or 23 spline..can anyone help me out what spline a 91 tranny is?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
