Old 01-27-2010   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Want to buy brakes and hubs
Just seeing what people have before I have to go to the U pull yard
Looking for
DSM
Front Hubs
Front Brake rotors
Front Brake calipers with hangers (big brakes if possible)
Rear hubs off of a FWD DSM
Rear brake rotors
Rear brake calipers with hanger
And by a slim chance does anyone have 4g csm Knuckle assembly
Old 01-27-2010   #2
TurboDomestics
TurboDomestics's Avatar
Re: Want to buy brakes and hubs
1g or 2g? IM assuming 1g, but if you need 2g stuff PM me. Ive got all of that.
4G63 0, Charlie 3
Old 01-27-2010   #3
Andrew7dg
Andrew7dg's Avatar
1g stuff
Note
I have the 4g knuckle assembly now
Still looking for other stuff
Old 01-27-2010   #4
i went to U Pull in Rosemount about a week ago and there was a 1g GSX there. When I was there, the trans, turbo, im, ic piping and most of the interior was gone. other than that, the rotors, calipers were still there.
Old 01-27-2010   #5
if you want to run disks on the back of the csm you will need the 3g csm set up 1g parts dont work with a ton of welding and custom fab.
Old 01-27-2010   #6
Andrew7dg
Andrew7dg's Avatar
Yeah just found this out...
Found a place to order the 3g sedan hubs though.
However can you use the brake setup from a 1g? AWD or FWD?
Old 01-27-2010   #7
you can use the dsm rotors and calapers fwd
but you will need the csm 3g disk brake brackets with out them you cant swap it over
Old 01-28-2010   #8
Andrew7dg
Andrew7dg's Avatar
Do you mean the hanger for the caliper or the bracket that holds the hanger?
89Mirageman will make a set of bracket to bracket to convert drums into disk. Or I will have to find a set from a mirage gt
which are sort of rare... to find. Mitsubishi doesn't make one anymore.
Unless you feel like fabricating some up?
Damn just last week I finally threw away my whole front brake setup since I did the cobra upgrade. You're a week too late!!!
NOO!!!!.... o well...
Someone else must have a set laying around from an upgrade. It is cold right now and I don't really want to go to u pull just yet.
Old 01-27-2010   #9
