Old 01-29-2010   #1
93tsiawd
Drives: 90 gst
4g63t modded estimated awhp?
not sure if this is in the right section or not but here it goes..i was jw what u guys thnk i should be gettn at the wheels..
1g 6bolt 4g63t:
small 16g
ported o2 housing
tubular manifold
full exhaust
fmic kit
intake
Apexi Safc- tuned
E85
550cc-650cc injectors
walbro 255 lph
lmk what ya guys think thanks guys!
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 01-29-2010   #2
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 4g63t modded estimated awhp?
I think you should be running premium with those injectors. Way too small with e85
FPR?
Do you have an O2? data logger of some sort?
Are all of these installed?
but just based on the turbo, eh 325ish
They are nice turbos. I put mine through quite a bit before she blew.
Old 01-29-2010   #3
It all depends on what dyno you are talking about. On a good tune (by Shane)on DB's dyno, maybe 265-285 range on E85(if the injectors are big enough as Andrew said), probably in the low 200's with pump. MAP's dyno has read anywhere from 12-18% higher than that.
Old 01-29-2010   #4
93tsiawd
Drives: 90 gst
no data logger im using a safcll..what about some 850'c as injectors?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #5
93tsiawd
Drives: 90 gst
oh forgot to mention the car will run on 15psi for daily driving
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #6
really depends on the tune and condition of the motor as well. Could be less than 200whp for all we know. Never know until you strap it on. Since it says you are in siox falls, try to find a local place to bring it to.
Old 01-29-2010   #7
93tsiawd
Drives: 90 gst
well the motor is going to a shop this weekend its for my project its gettn new pistons rods etc..its pretty much gettn a rebuild so the motor will be fairly new..we have a shop here in town with a good reputation Excessive Autosports i was thinkin of just havin it done here by joey
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #8
Based on my expirence, im going to say 250 or less at the wheels. Mainly because of the SMALL 16g and the 15psi. When i had my small 16g on my last 2g, after spoolup it seemed to basically fall off on the power, (butt dyno). This was with 680cc injectors. on this 1g that i just bought, once i get it running, im not really sure how long it will keep the Evo 3 16g turbo on it, im used to much bigger turbos and i feel like im going to get the itch and upgrade. But ive never had an evo 16g on my car so who knows.
Some of the more effective mods to help your setup:
Bigger turbo, even if its an evo 16g or 50 trim.
Heavier clutch to transfer the power from the crank to the wheels better.
Bigger injectors
2.5" FMIC Piping (if not already there)
Cams
SMIM
Those are just some items that will give you a definite increase in power. After that you are looking in the range of the low to mid 300s.
Old 01-29-2010   #9
Constant_Project21
Constant_Project21's Avatar
Drives: E36
If you're running e-85, at the least run 880 injectors. I really don't think a SMIM is necessary. Plenty of people making a lot of power on stock intake manifolds. I liked my small 16g turbo, made quite a bit of power (but dyno, also had hks 264's) but I was also running 20psi, that was spiking to 24psi. I'd say a ported s16g, with adequite fuel, could make high 200's at db. It's still gonna be very fun to drive, mine sure as hell was. But at 15psi, expect mid 200's. Oh need to add a wideband to that list.
Btw-have that front mount still, I can take pics today.
Old 01-29-2010   #10
For comparison, this is the dyno sheet from my old 16G setup on my 1g:
Hahn Super 16G (8cm^2 exhaust housing)
-FMIC
-650's
-FMIC
-3" exhaust
-MBC
-272's
-walbro 255lph
-bunch of other things also, but these are the basics.
This was on 91 octane at 23 psi on DB's Dyno Dynamics
Old 01-29-2010   #11
93tsiawd
Drives: 90 gst
For comparison, this is the dyno sheet from my old 16G setup:
-FMIC
-650's
-FMIC
-3" exhaust
-MBC
-272's
-walbro 255lph
how much whp were u making on that setup? o btw what u guys thnk is a safe amount of boost to run on the setup im talking about?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #12
It says right on the graph.
Old 01-29-2010   #13
93tsiawd
Drives: 90 gst
aight..how about 20 psi, 850cc injectors, e85, n a very good safcll tune? maybe around 250ish?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #14
My brother's blue car had a very similar setup for a while, but with a clipped big 16g and comp 101200 cams. On pump gas, untuned and pig-ass rich (9:1) it made 211whp at like 18psi. With a propper S-AFC tune I'm sure it would have made more like 235-240whp.
Those injectors and the S-AFC won't do E85 worth isht, you'll need dsmlink and ~850's or something for that. I would expect 280whp or so pretty easily.
All of these numbers are on DB's dyno dynamics, which does read pretty low, and assuming you get a good tune done.
Old 01-29-2010   #15
viridionplague
dyno graphs are measured at the wheels. i would say around 20 ish psi. give or take a few depending on how your car reacts to everything.
Old 01-29-2010   #16
Your whp numbers will also depend a lot on the brand of dyno used and whether it's dynoed AWD or FWD. You would see a good 20-20% higher numbers on Excessive's Dynojet with the car converted to FWD than an AWD Dyno Dynamics.
Old 01-29-2010   #17
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I made 210 awhp with a simular setup on pump
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-29-2010   #18
mike55112
mike55112's Avatar
Drives: 04 evo
I remember sleepydsm made 210 with his 14b,stock cams, around 20psi and maf-trans.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 01-29-2010   #19
GsXtUrBo98
GsXtUrBo98's Avatar
Its possible.. 800's are still kinda small for e85 though
98 GSX (built)
03 BBY EVO dd
Old 01-29-2010   #20
850's will be just fine. 95tsi is maxing the shit out of his e316g (30 psi, 40lbs/min) on a 2.3 and has 880's. Maybe he can chime in on what his injector duty cycles look like.
