Old 02-05-2010   #1
v8klla
v8klla's Avatar
MAPerformance / First to break 800whp barrier on stock Evo ECU!
Build Summary
The license plate on this Evo says it all, Evil AWD. We had two goals for this build and as far as I can tell we were successful in both regards. The first goal was to fulfill our customer's request which was to take his daily driver and make it into a monster that he could still drive on a daily basis. Thanks to Kasey's time and effort in regards to tuning combined with the proper components we have accomplished just that. Our second goal was to utilize this opportunity (we rarely see builds like this in Minnesota, even though they seem to be so prevalent in other parts of the country) and break some records. Drag racing in February just isn't possible here in Minnesota, so for now dyno numbers will have to suffice
New Stock ECU Horsepower Record as of February 5th, 2010
As far as we can tell 814whp beats the previous stock ECU horsepower record by over 40whp! As you can see below we were also able to reach 806whp at just 38psi, which leads us to believe that there is room to grow Look for updates in the near future as we get to spend more and more time in our dyno room with this monster!
Modifications
MAP 2.3L Shortblock
  • MAP Spec 10:1 Wiseco Pistons
  • MAP Ultimate Duty Connecting Rods
MAP Stage 4 Cylinder Head Preparation
  • Kiggly Racing Beehive Valve Springs / Retainers
  • Kelford 272 Camshafts
MAP Custom Top Mount T3 Manifold / Downpipe
PTE Billet 6765 Ball Bearing Turbocharger
MAP Custom Intercooler Piping
Perrin Intercooler Core Modified for 3" Outlet
3.5" GM MAS / MAF Translator
Mil.Spec 65mm Throttle Body
MAP Rev3 Intake Manifold
Sparktech Non-CDI Coil on Plug
Full Blown Triple Pumper
Fuel Injector Clinic BlueMax 2150cc Injectors
We just can't say enough about these fuel injectors as they have quite honestly changed the game in regards to power output and driveability. Clearly, they are able to support well over 800whp on E85. The part that you can't see from these dyno charts is the driveability. Here in Minnesota we frequently dip below zero degrees and rarely get above freezing in January / February. With that said, this car starts like a dream! Part throttle and cruise characteristics are similar to what was once only achievable with injectors smaller than 1000cc. Finally, you can have your cake and eat it too when it comes to fuel injectors for the Evo platform!
Special Thanks
We would like to take a moment and thank all of the stock ECU gurus for their time and effort, without their innovation and ambition none of this would be possible! We would also like to thank JestrTuning and JohnBradley for their collaboration efforts during this project!
Dyno Charts
Please note that we have included both STD and SAE correction to keep everyone happy Yes it is cold outside up here in Minnesota, but our dyno room draws air from our 65 degree workshop. Either way, the correction factor takes temperature into consideration.
Build thread and dyno videos coming soon!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-05-2010   #2
Re: MAPerformance / First to break 800whp barrier on stock Evo ECU!
Heard of this last night..congrats!!!!
Old 02-05-2010   #3
Badass, but why only k272's and wtf@maf-t? Speed density suckas, dooo it!
Old 02-05-2010   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Hahaha gm Maf ftw! Awesome numbers!
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-05-2010   #5
v8klla
v8klla's Avatar
Thanks for the kind words guys!
In regards to the cams this is an honest to goodness daily driver, did you catch the fact that it has a stock ported intake manifold? We've put 700 miles or so on it at the customer's request and it handles Minnesota winter like a champ!
In regards to the MAFT you would have to speak with Kasey on that one. I believe he chose to stick with what he knows for now so there weren't any variables to prevent us from reaching these goals. However, speed density is definitely going to be a part of our repertoire in the future!
P: 763-545-3800
Old 02-05-2010   #6
Kasey at MAP
Drives: E-85 '03 Evo
Send a message via AIM to Kasey at MAP
Speed density sucks
Fixed
Kasey at MAP is offline   Reply With Quote
Old 02-05-2010   #7
Originally Posted by Kasey at MAP View Post
Fixed
Watch out, I'll show that to JohnBradley/Aaron@ER, IDK if he'll think that's very funny
Old 02-05-2010   #8
Kasey at MAP
Ok, I know SD is a big hype right now, but no one has really proven it to be better than using a GM MAF. We are using a 3inch upper IC pipe with a 3.5 GM Maf and I will bet you the restriction is not hurting the power at all or spool for that matter.
Old 02-05-2010   #9
Badass, Congrats
Old 02-05-2010   #10
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
dayum. pretty nice stuff guys
ლ(ಠ益ಠლ)
Old 02-05-2010   #11
mike55112
mike55112's Avatar
Drives: 04 evo
Looks like a sick build. I knew there was a reason I went back to the stock ecu.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-05-2010   #12
Awesome, congrats!
I have to admit, first time I've heard of a MAF-T used on an Evo. With speed density being as easy to set up and reliable as it is I don't understand why that wasn't used.
You don't build an 800WHP+ car to be streetable, put bigger cams in it and make more power.
Old 02-05-2010   #13
v8klla
v8klla's Avatar
Awesome, congrats!
This build has been in the works for quite some time to be honest. Speed density was relatively new when we were in the planning stages and we just don't have enough Evo's in the area to get accustomed to the intricacies of speed density We have three Evo owners at the shop, but one is down for upgrades, another is trying to sell, and the third is my daily driver! lol
Also, Kasey used this combo the last time he broke the stock ECU record
P: 763-545-3800
Old 02-05-2010   #14
http://mitsustyle.com/forums/showthread.php?p=318644
Kid tested, mother approved.
By that, I mean all the openecu dudes (including JohnBradley) signed off on this...your DD is an 05 isn't it? You need to try this, srsly. I'm working on the IX one next, stay tuned
Old 02-05-2010   #15
v8klla
v8klla's Avatar
Yes, 2005 MR. I realize more and more people are going speed density, and I'm not knocking it at all as it appears to be the future of Evo tuning. It was just one less thing for us to worry about for the time being, and clearly the MAFT combination works
P: 763-545-3800
Old 02-05-2010   #16
Congrats, our car scene is better than you think.
Old 02-05-2010   #17
v8klla
v8klla's Avatar
I think it mostly has to do with winter as most anyone considering a build like this would have to drive something else 6 months out of the year lol. It just makes me a little bit sad that the first big Evo project to come through my facility was from North Carolina!
P: 763-545-3800
Old 02-05-2010   #18
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
That thing spools really good. Sweet shit.
'04 Honda Ricer: stock
Old 02-05-2010   #19
Good work guys. I agree that a MASS sensor was a good choice for this project. Customer wanted a daily driver with repeatable and dependable results, why not use a MASS sensor over calculations, IAT, and map sensors. Speed density rocks, but you can get a car PERFECT with a MASS when it comes to drive-ability and idle.
Old 02-05-2010   #20
jrohner
jrohner's Avatar
And for the time it takes to get SD right (for driveability, not just dyno numbers), you could've spent that time on things that would actually give you gains.
