Old 02-10-2010   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
V8 Busa?
http://www.h1v8.com/page/page/1562068.htm
This isn't new to some people probably but I found it pretty interesting and Neat looking
75° odd fire V8
2.8 LITER, 170 cu. in. displacement (3.0 liter optional)
84mm Bore X 63mm Stroke (67 stroke optional)
4 cams, 32 valves via internal silent chain
530mm wide x 485mm long x 530mm high
400HP @ 10,000 rpm with stock street cams (higher spec. is available)
245 ft-lbs torque @ 7500 rpm
200 lbs engine weight
Billet nitrided steel 180° crank
4340 H-beam con-rods with ARP bolts
Billet 6061-T6 aluminum crankcase
Dry sump 0il system with 4 stage pump
7.25" or 5.5" Twin disc clutch
DTA S80 full sequential ECU
Unique cylinder offset and cam drive
So that light compact V8 in something like this
FUN!!!!!!
Old 02-10-2010   #2
Re: V8 Busa?
Small displacement high revving V8s, gotta love 'em. Dry sump, too.
Old 02-10-2010   #3
Re: V8 Busa?
Very badass!
Old 02-10-2010   #4
LingLing
AznKraut
LingLing's Avatar
Re: V8 Busa?
That's pretty sweet! I wonder how it would keep up with the Atom.
Old 02-10-2010   #5
Andrew7dg
Andrew7dg's Avatar
Re: V8 Busa?
It is going to be put into the Atom
Old 02-10-2010   #6
Re: V8 Busa?
If you look closely, it's already in the Atom
Old 02-10-2010   #7
LingLing
AznKraut
LingLing's Avatar
Re: V8 Busa?
That'll be wicked fast.
Once that's in Top Gear should re-test it!
Old 02-10-2010   #8
Re: V8 Busa?
So this is two busa motors stuck together with a custom crank? That's pretty bad-ass. I love the packaging idea, even for the 4-cyl version! Does it say how much it weighs?
IDK, for the money I'd prolly still take an evoIX or evoX longblock w/ a few basic mods on it, rev it to 8000.
Old 02-10-2010   #9
Andrew7dg
Andrew7dg's Avatar
Re: V8 Busa?
ONLY 200 freeking pounds!!!
Old 02-10-2010   #10
Re: V8 Busa?
200 pounds holy eff!
