Old 04-15-2004   #1
2003eclipse
Slower than a rusty Honda
2003eclipse's Avatar
03 3g 2.4 5spd manual
When I take off I can feel my stick hesitate and vibrate when im putting it into gear. 2nd and 3rd gear mostly noticeble in 4th and 5th also. would some redline tranny fluid help it out?
just let me know what you guys think it could be. if someone wants to drive it and feel for themselves let me know.
joe
I LIKE TURTLES
Old 04-16-2004   #3
520Talon
There really isn't anything you can do. Try changing your fluid. The only other thing is to rebuild it and hope its better. Some cars are just kind of notchy. My Audi's tranny is so notchy it makes my Talon feel like a $100,000 car.
520Talon is offline   Reply With Quote
Old 04-18-2004   #5
That was your mistake, letting JDM drive it, it will never run right again. Shit he shook Nashs hand yesterday and look what happened.
CRAIG
Has it had hard launches on it? Just guessing but your flywheel could be warped, hard to tell without seeing or feeling it first hand.
Old 04-18-2004   #6
That's not a good thing!!
Old 04-18-2004   #7
1Fst14B
Send a message via AIM to 1Fst14B
Originally posted by 2003eclipse@Apr 16 2004, 09:09 AM
NO ADVICE?
i should rather say when i go up through the gears and also down shifting it acts up like that
Well, its a 03...does your car NOT have a warranty???
why dont you just go to a mitsubishi dealer and see what they say?
1Fst14B is offline   Reply With Quote
Old 04-18-2004   #8
2003eclipse
it has 36,000 on it and i will most likely tear into it someday its such a basic car. whoa warped flywheel never thought of that seriously it has hard launches on it i told you i let jdm drive it. lol no i've raced it but usually i launch at 2200 rpm tops. but damn a flywheel would suck jut to fix something so simple i guess if you know what i mean. i'll try fluid first then go from there
i'm willing to let anyone drive it. that has more of an idea then i do.
I LIKE TURTLES
Old 04-18-2004   #9
JustROLLIN
SpunBearing
JustROLLIN's Avatar
The warranty is only 3/36k? If you are still under warranty Joe, take it in. You paid for it, may as well use it.
Has the fluid been changed in the tranny yet? The fluid SHOULD be changed yearly, but no one does that. I would say that is a good place to start becaue you can check the conditon of the fluid. There will some copper/brass material in the fluid. The copper/brass material is the soft metal used on the sychronizers, it is meant to wear away over time so that the gears do not grind when going into gear.
