Old 02-17-2010   #1
CarPsyco84
CarPsyco84's Avatar
Transmission assembly goop suggestions?
So what do you guys that build transmissions use when you reassemble the case to keep it from leaking all over the place, I thought about using black RTV but figured that might not work that well on a actual flat surface... Any Idea's?
-When in doubt, Moar RPM.
Old 02-17-2010   #2
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Re: Transmission assembly goop suggestions?
the red sealant thats used between aluminum on transmissions is called anaerobic sealant.
Jungy is offline   Reply With Quote
Old 02-17-2010   #3
CarPsyco84
CarPsyco84's Avatar
Thanx, I knew there was something other than RTV, that worked better.
Old 02-17-2010   #4
Gray RTV works good, Jack from Jack's transmission says that its good to use.
Old 02-18-2010   #5
Gray RTV .
Bingo.
Old 02-18-2010   #6
I've used a those high temp RTVs on the end cases wayyy back in the day when we had to swap viscous couplers out on them awd carzzz! Never had one leak.
Old 02-18-2010   #7
I've also used Gray RTV with good success in the 20+ something dsm transmission I've rebuilt over the years.
