Old 02-23-2010   #1
scorcho96
Drives: LS400 LSx
Staggered Wheels on AWD
I was curious if you could run staggered wheels on an awd? Particulary an awd 1g? My cousin has a 335xi and he was also curious if he could run staggered wheels on his car? Does it cause damage to the drivetrain? Thanks
scorcho96 is offline   Reply With Quote
Old 02-23-2010   #2
Re: Staggered Wheels on AWD
Do you mean width or circumference? You can run different widths (though I don't know why on a street car) but the tires must be the same circumference all around. If you have different sizes of tires it will cause excessive wear on the differentials.
Also, being close isn't good enough. That's why you need to replace all four tires on an AWD car even if one is bad, or have the tread on the new one shaved down to the same height as the other three.
Old 02-23-2010   #3
Originally Posted by matt d. View Post
do you mean width or circumference? You can run different widths (though i don't know why on a street car) but the tires must be the same circumference all around. If you have different sizes of tires it will cause excessive wear on the differentials.
Also, being close isn't good enough. That's why you need to replace all four tires on an awd car even if one is bad, or have the tread on the new one shaved down to the same height as the other three.
+1
Old 02-24-2010   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
/thread.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-23-2010   #5
As long as the rolling diameter of the wheels is the same on all 4 you will be fine. That could be hard to do though with different widths and heights of the tires from front to back.
Old 02-23-2010   #6
b00sted_spyder
If he's planning on using the wheels from the 335xi, it won't work because BMW has a 5x120 pattern.
Old 02-23-2010   #7
All I've ever seen is theory on this. I'm convinced if the rolling diameter is within 1-2% from front to back, there will be no issues. Considering most DSM's out there these days are running four different tires and I'm not seeing blown VC threads every week, I'm inclined to think it's not much of an issue. I'm going staggered on my 1G this spring when I find a deal on the narrower front wheels I need. I'll report my findings of actual real world data.
Old 02-23-2010   #8
^Its official you have lost your mind.
Old 02-23-2010   #9
Yeah, but wait to you see the tuck, pure sexy baby. You can't hang.
Old 02-24-2010   #10
You joinin' hellaflush?!? Google it if you have no idea what I'm talkin' about.
Old 02-24-2010   #11
95tsi
95tsi's Avatar
Drives: a pos
Stock Jeep SRT8: 255/45-20 front and 285/40-20 rear Factory OEM runflat Goodyears.
Old 02-24-2010   #12
Oh, I know, I've looked at thousands of pics when I was deciding which wheels to get.
Not quite what I'm going for, for me it's more about sitting flush with wheel lips. I've always hated that the rear wheels sit farther inboard relative to the fender lip than the front, even more so with my shortened rear lower control arms done before there was any sort of camber adjustment made for 1G's.
Old 02-25-2010   #13
It's good to know not all of your styling is from the 80's .
I do remember having a 7.5" rear wheel with a +32 offset being kinda flush-er than your avg wheel. This is what i was using when I bought my new wheels......
http://www.1010tires.com/WheelOffsetCalculator.asp
It helped a lot in all of the wheel options' flushnesses when looking at other people's wheel setups.
Old 02-23-2010   #14
scorcho96
Drives: LS400 LSx
No im not using bmw rim's. I was just curious if the rims are both 18's but the rear are wider than the fronts. also my cousin is buying 19's for his 335xi and he asked me if he could run 245 width in the front and 275 width in the rears without ruining things. (both rims being 19 inchs). Thanks
Old 02-23-2010   #15
Even though the wheels are the same diameter, the tires may not be. You would have to calculate the rolling diameter of the tires and make sure it's the same between the sizes. A 245/45/18 tire isn't the same diameter as a 275/45/18.
Old 02-23-2010   #16
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
if you have the right tire size number like 205 40 r what ever it wont matter as long as it isnt like a 205 45 r what ever because im pretty sure that one tires gonna have a little bit less tread then all the other 3
Old 02-23-2010   #17
As long as the rolling diameter of all 4 tires are the same, you will be fine. End of thread.
Old 02-23-2010   #18
At Discount Tires, we can not install staggered rims onto awd vehicles because of any issues that involve the possibility of drivetrain damage. Personally...I would put it on just for the 'badass' look LOL, but I haven't seen any real world damages with awd having staggered fitment. But, having if you have 205 fronts with 245 rears, it will eventually possibly damage the drivetrain because of different traction the tires have.
I can see having 18s all around with +25 fronts/-5 rear offset with the same tire size...but the tires have to be the same all around.
(note: in class right now if post doesn't make sense ...)
Old 02-23-2010   #19
Staggered as in the width, not the circumference.
Old 02-23-2010   #20
Ok some of you clearly don't understand what the numbers on a tire sidewall mean.
lol...so a 60 series is low profile right? lol.
that's what i meant.
hmm...googled 'staggered talon' and found this
