Old 03-14-2010   #1
b00sted_spyder
Dowel pin
I'm having troubles with bolting the transmission onto the block. Are there suppose to be dowel pins on the transmission?
Old 03-14-2010   #2
Re: Dowel pin
Yes, I believe they are on the front and back side of the motor/trans.
Be careful they can come out of the transmission so just lightly tap them with a mallet.
Old 03-14-2010   #3
Re: Dowel pin
They are very important, good thing you noticed they were missing, not everybody catches that and it causes problems.
Old 03-14-2010   #4
b00sted_spyder
Re: Dowel pin
Are there a total of 4 dowel pin when mounting the transmission to the engine(2 on each)? I had a problem mating them together because they are touching eachother and are located on the same mounting hole.
Old 03-14-2010   #5
Chim55117
Drives: 2007 BMW 335i Coupe
Re: Dowel pin
Also make sure you have the correct starter plate.
Chim55117 is offline   Reply With Quote
Old 03-14-2010   #6
b00sted_spyder
Re: Dowel pin
I do have the correct starter plate and it is brand new.
Old 03-14-2010   #7
iceminion
iceminion's Avatar
Re: Dowel pin
there are two dowel pins, however I could see if you are connecting a transmission from a different cars, the pins could be still in the transmission, and also in your block.
remove the two worst ones, and install the transmission
building a 3000GT AWD Turbo.
Old 03-14-2010   #8
b00sted_spyder
Re: Dowel pin
Yes, that is exactly what I'm dealing with. Here's my problem, I removed 1 of the dowel pin on the transmission fine and the other one is stubborn. It won't budge at all. Seems like it's meant to stay there. Anyone have any tricks on removing these little stubborn bastards?
Old 03-14-2010   #9
iceminion
iceminion's Avatar
Re: Dowel pin
Well, heres the thing, there is no "right" side to have them on, so I would assume if ONE of the pins is being a bitch, remove the other one.
its ok to have one dowel pin in the engine and one in the transmission, its not that big of a deal
however if you REALLY want to remove it, bring it over to my house and I will remove it for $10
I live in saint paul
Old 03-14-2010   #10
iceminion
iceminion's Avatar
Re: Dowel pin
Oh, and its not "meant to stay there" trust me. You can remove it, no biggie.
Old 03-14-2010   #11
b00sted_spyder
Re: Dowel pin
I don't want to remove the ones on the block because they are brand new. I guess tomorrow's project will be removing that POS so I can get the transmission bolted to the block. I'll let you know if I can't take that pin out. Thanks!
Old 03-14-2010   #12
Re: Dowel pin
Just grab them with a vice grip and start twisting, they should come out. Since you have new dowel pins in the block, you don't need to worry about re-using them.
Old 03-15-2010   #13
Re: Dowel pin
put the bolt in it and use vice grips. the bolt in it will stop it from crushing the pin
