Closed Thread
Old 05-16-2010   #1
Twitch
Twitch's Avatar
Drives: 2005 GTO, 2006 Duramax, 92 turbo civic, 85 Grand National
Send a message via AIM to Twitch
Wierd feeling when on gas
My car feels like im driving on flat tires when i press on the gas and idk why. My wheels are balanced and the lugs are tight. The steering wheel does not shake a all. Idk whats goin on and i need some help..
I was thinkin axels.
Twitch is offline
Old 05-16-2010   #2
Re: Wierd feeling when on gas
could be a TON of things.
Swifty1638 is offline
Old 05-16-2010   #3
Chim55117
Drives: 2007 BMW 335i Coupe
VTEC must not being kicking in.
Chim55117 is offline
Old 05-16-2010   #4
^ truff. Solenoids these days sometimes get stuck.
Old 05-16-2010   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
You probably didn't get all the RTV out of the VTEC solenoid. Or maybe you're just running the butthurt/fuel level way too high.
But seriously, flamidation valve, check it.
How do you know what driving on 4 flats feels like, anyway?
Originally Posted by Trogdor
cmspaz is offline
Old 05-16-2010   #6
it was probably all the toes you ran over as you backed into that spot all quick-like, almost taking out spilner's eclipse and making it blow up-and yes, I was standing there/one of the said characters you almost ran over btw, how do 13 year-olds get cigs to smoke?
Old 05-17-2010   #7
If it had anything to do with the wheels/tires/suspension and probably the axles, you would feel it in the steering wheel.
It almost sounds like your balance shafts aren't aligned correctly.
Matt D. is offline
Old 05-17-2010   #8
Twitch
Twitch's Avatar
my balance shafts are gone
Twitch is offline
Old 05-17-2010   #9
Then make sure your timing marks are correct.
Matt D. is offline
Old 05-17-2010   #10
Something probably bent/broke when you fucked up the wheel and tire when you hit that pot hole. I would check the camshaft alignment.
Kevin 1G Drummer is offline
Old 05-17-2010   #11
Twitch
Twitch's Avatar
No because everything was perfect with the car until Saturday night
Twitch is offline
Old 05-17-2010   #12
Your car is probably going to run that way, until you return the spare wheel you borrowed from that dude on here.
A//// Guy is offline
Old 05-17-2010   #13
Twitch
Twitch's Avatar
ok..i pm'd that dude like twice soo i could get his number and he never replied and i just got off like a 1 month ban..
Twitch is offline
Old 05-17-2010   #14
Yet you were pretty quick to get in your car and leave when he tried to approach you at the dyno day?
As to the problem with the car... the gas tank bolts might not be tight enough.
Old 05-17-2010   #15
polishmafia
Smells like cat poop
polishmafia's Avatar
Well what changed between Saturday night and Sunday night?
polishmafia is offline
Old 05-17-2010   #16
Did you turn your hat from straight to sideways when you noticed this change in driving?
Old 05-17-2010   #17
lol, and my comments aren't welcome.
Are all the tires feeling flat or just the front or back?
turbotalon1g is offline
Old 05-17-2010   #18
Check your tire pressure.
Kracka is offline
Old 05-17-2010   #19
Twitch
Twitch's Avatar
tire pressure is fine and it feels like the fronts. I nvr knew he was even at dyno day
Twitch is offline
Old 05-17-2010   #20
Can you maybe post up some info on the car? And a better description of the symptoms would help. It's hard to help anyone when it's this vague.
So it only does this when you are accelerating? So under normal cruising throttle it's fine? What does it even feel like if you can't feel it in the steering wheel, because a flat tire usually you can feel something in the steering wheel like pulling to one side or something. Is the car just bouncy or something?
First thing I'd do is get the wheels checked again, especially if you hit a pothole.
If it's AWD it might be a carrier bearing issue.
And I was also there when you raced into that parking spot like Whoa!
Halon is offline
Closed Thread
