Old 05-25-2010   #1
The 92 Laser
The 92 Laser's Avatar
Drives: Turbo Miata
new motor wont get fuel into cylinder.
It is a brand new fully built motor and when turning over the rail is getting pressure but there isn't fuel going into the cylinder.
It could be the injectors, but the guy I bought them from seemed legit.
The injectors are 1600cc and we are using e85.
I bought the car with broken injector clips and soldered the old wires into new clips from a late 90s diamante.
So it could be a couple of things but wouldn't the injector clips be the same from that car, because it is still a 2.0 4g63 just NON-turbo.
Please help because this beast needs to run.
Thanks,
Colin
The 92 Laser is offline   Reply With Quote
Old 05-25-2010   #2
enasnitsi
Drives: 1993 Talon Awd
Re: new motor wont get fuel into cylinder.
Do you have power to the injectors and is the ground good to them?
enasnitsi is offline   Reply With Quote
Old 05-25-2010   #3
Make sure you have the correct plug into the Injector Resistor pack, i failed on this one.
Also try swapping out the injector resistor pack?
If you are not getting voltage to the injectors its likely the resistor pack.
Old 05-25-2010   #4
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
The injector resistor pack never got touched.
We will try swapping out the resistor pack.
We also have not tried to see if we are getting power to the injectors or not. But we will tomorrow morning. Just seeing if we can cover all our bases before jumping to conclusions.
-Colin
Old 05-25-2010   #5
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
PS where do the injectors ground out?
-Colin
Old 05-26-2010   #6
ECU if I'm not mistaken.
Old 05-26-2010   #7
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Thats what I thought too. one wire from the resistor and one wire from the ECU.
-Colin
