Old 06-15-2010   #1
Constant_Project21
Constant_Project21's Avatar
Drives: E36
1ga parts
We are in the process of tearing apart a 1ga shell that will eventually end up in the crusher. If you need 1ga parts, let me know and if its still there I'll get ya a price. The motor, tranny, i/c set up, and the seats and carpet will be taken, but if you need small stuff, call/text me at 651-468-6391, or pm me on here.
Car is a red 90 gsx 5 speed by the way.
Old 06-15-2010   #2
aaronspeed
Drives: 1991 Eagle Talon AWD
Re: 1ga parts
Left/drivers rear caliper if it has a working emergency brake. Shipped 43334.
Thanks
Aaron
aaronspeed is offline   Reply With Quote
Old 06-15-2010   #3
viridionplague
Re: 1ga parts
does that thing have a good 4 bolt rear end?
Old 06-15-2010   #4
Re: 1ga parts
Is this the car with the strips you told me about?
I'm looking for the ones that go thru the center of the door. They don't have anything written on them.
Old 06-15-2010   #5
aaronspeed
Re: 1ga parts
I also could use the front turn signal sockets and about 6" of the wiring . Left and right.
Old 06-15-2010   #6
Constant_Project21
Drives: E36
Re: 1ga parts
Once everything is stripped, I can pull those for you.
Old 06-15-2010   #7
Constant_Project21
Drives: E36
Re: 1ga parts
E-brakes are shot.
It has a stock 3 bolt, seeing as its a 90.
Aaron, are you talking about the ones on the outside of the door. Pic would greatly help, Im most likely not using them.
Old 06-15-2010   #8
Re: 1ga parts
If it has an intact E-Brake cable I'd take it. How are the interior plastics?
Old 06-15-2010   #9
Constant_Project21
Drives: E36
Re: 1ga parts
Im gonna be taking the ebrake cable, the plastics are in good shape, which ones do you need?
Old 06-15-2010   #10
Constant_Project21
Drives: E36
Re: 1ga parts
Will take some trades if you want a bunch of stuff, I could really use a fmic core!!
Old 06-15-2010   #11
aaronspeed
Re: 1ga parts
I will take them when you get it stripped. How are the front turn signal and the side lenses. How about the drivers/left side headlight motor.
Old 06-15-2010   #12
Re: 1ga parts
Center of the door, I need both sides.
Old 06-16-2010   #13
Constant_Project21
Drives: E36
Re: 1ga parts
Yep have those, they're yours free if you come by and pull them. I don't wanna risk messing them up haha.
Old 06-16-2010   #14
viridionplague
Re: 1ga parts
how fast are the wipers? if they go a normal fast pace i might want the wiper motor
Old 06-16-2010   #15
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 1ga parts
I need the front clear lens assembly. I live close to you and can pick it up even. Possibly the light cover also for the passenger side
Old 06-16-2010   #16
Re: 1ga parts
I need the clips that hold the rear wing onto the trunk lid!
Old 06-16-2010   #17
Constant_Project21
Drives: E36
Re: 1ga parts
Im guessing they work just fine, I havent seen them in action. I can test them, and shoot ya a text.
Send me a text, make an offer on them.
If my friend isn't using the spoiler, then I'll pm you.
Old 06-16-2010   #18
Re: 1ga parts
^sweet will do, thx man
Old 06-17-2010   #19
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: 1ga parts
dan, can I have the stock downpipe to hack up?
Style's automotive engineer
Old 06-17-2010   #20
Constant_Project21
Drives: E36
Re: 1ga parts
It's a 3inch downpipe, with no flange to hook up a catback. Owner did some "custom" exhaust work.
