Old 07-03-2010   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
WTB: FWD parts
I need a couple more parts for my talon piecing together.
All these are for a 1g FWD Tsi:
All motor and tranny mounts
turbo feed and return for a 14b oil and coolant.
Turbo coolant pipe (along the engine)
brake booster cable.(the vacuum one)
axles for a FWD, 91+ preferably
Clutch and flywheel for a FWD, either used or new will work.
starter, I think AWD and FWD are the same. who knows.
Alternator.
91+ Throttle Body
I think that should be it for now, I will be going through what I have on monday to get a 100% Idea what I need.
Thanks,
Colin
Old 07-03-2010   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: WTB: FWD parts
I have a flywheel and clutch. Its an autozone clutch. Iam sure I have a starter laying around here. 50 bucks and its yours. The clutch worked when I pullied it out has mabe 5000 miles on it.
Old 07-03-2010   #3
Re: WTB: FWD parts
Got
Turbo coolant pipe
Alt
have the block mounts and should have the tranny mount
For axels use awd front axels that is what was in the car. So they are the same lenght
The starts are the same awd or fwd.
Old 07-03-2010   #4
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: WTB: FWD parts
Ok, will do.
When can I pick that stuff up? Weds at the meet? or monday works too.
How much do you want for all of that?
pipe, alt and mounts.
-Colin
Old 07-03-2010   #5
Re: WTB: FWD parts
I can bring it all on wed to the meet
Do 60.00 for it all
Old 07-03-2010   #6
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: WTB: FWD parts
sounds good
-Colin
Old 07-03-2010   #7
Wizard
Re: WTB: FWD parts
The passenger side axles are the same for FWD/AWD. For driver's side, the FWD axles is a long single piece axle. AWDs had a intermediate shaft that bolted to the block and then used a smaller axle that went to that. It was part of the equal length axle setup. It was designed to reduce torque steer (why it was never in a FWD we'll never know) and to also help clear the T-case. You can run the AWD setup in a FWD though, just need the pieces.
You can use transmission or hp fuel hose for the brake booster line (make sure it's High Pressure).
Wiz
Old 07-03-2010   #8
viridionplague
Re: WTB: FWD parts
ive got the bigger AWD brake booster with the hose, and a throttle body. you can have all of it for 40 bucks
