Old 07-07-2010   #1
FS: 1G Intake Heat barrier Gasket - $35/obo
Brand new never used.
A special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C and only takes 2secs to install with intake manifold off.
$35/obo
Old 07-07-2010   #2
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Re: FS: 1G Intake Heat barrier Gasket - $35/obo
Is this the MAP or Magnus version?
Old 07-07-2010   #3
Is it made by garage 16 in canada, the guy with the 9 sec 4G63 powered elantra sells them.
Old 07-12-2010   #4
bump
Old 07-19-2010   #5
Don't transfer that heat to your head, pick this up.
Old 07-30-2010   #6
SOLD!!!!!!!!!!!!!!!!!!1
Please delete
