Old 07-14-2010   #1
Tom's 92 1G Talon partout thread
Hey guys, So i have decided that this bitch needs to be parted out. The bearing spun and messed up the crank. Here is a short list of parts off the top of my head with approximate prices. Shoot me a pm if you want something.
1992 Eagle Talon TSI AWD
250 miles driven after the complete rebuild
Stock parts:
Transmission - Shifts perfectly not a single grind. $300
Head - Stock 6 bolt head resurfaced and completly cleaned up by MAP loaded with stock valves and springs. 4 valves were replaced on the #4 cylinder. $250
ECU - No issues with this. SOLD
4 bolt rear end - $125
Xfer Case - $100
Working hatch props - $40
Radiator (no leaks, no corrosion) $35
Throttle body - bottom half blocked off $25
Exhaust Manifold - $35
14b - No shaft play, some chips on exhaust wheel - $25
Intake manifold - Cleaned all carbon with 2 cans of degreaser and a brush $35
Full interior/exterior - Post what you need and ill give you a price.
Ask for any other parts you need
Aftermarket parts:
Thermal Exhaust turbo back - Very good shape with test pipe. - $500
Tial Q Blow Off Valve - $175 (looks new)
Crane Fireball Ignition ready for install - $125
XS Power FMIC Core - $60 (size: 24"x3"x6")
Black/silver Rota Slipstream 17" wheels with crappy tires - These look pretty good, one of them was repaired (welded on the lip) - $350
Shift Light with digital RPM display and peak readout - $40
Manley I Beam Connecting rods - $550(http://www.maperformance.com/manley-...ting-rods.html)
Mahle 040 over 8.7:1 pistons with wrist pins. (with this set i will give you 7 pistons, four for the car and 3 extras in case you need them as you cannot get these anymore) $300
Sheet metal Oil Pan - $50 (has a dent from where the rod cap had hit before the rebuild)
Oil Pressure gauge - $25
Boost gauge - $25
Lightened flywheel (not sure the brand) but still in good shape - $75
Solid motor mounts - drivers side and passengers side - $40
Motor mount inserts for front and rear - $10
Power Enterprizes Kevlar (blue) Timing belt - no cracks $25
Headlights (resurfaced) with HIDs - SOLD
Brand new 1gb dual piston Calipers with pads and slotted rotors (less than 250 miles on them) $200
ARP L19 Head studs - $100
ARP Main Studs - $45
2 cranks in need of resurface one with recessed oiling holes - $25 each
Shaved and polished Valve Cover - $30
FMIC piping 2" flanged for tial - $40
Taylor 409 Spiro Pro Race spark plug wires (excellent condition) - $45
I will try and get some pictures up today
Ill add more after i get home and look at the car, im sure im missing items.
Enjoy
Tom
Old 07-14-2010   #2
Re: Tom's 92 1G Talon partout thread
Can u shoot me some pics of the FMIC core please
Old 07-14-2010   #3
Heres a pic of the front of the car. i can take one with the bumper off tonight.
Old 07-14-2010   #4
91 tsi
Drives: 91 eagle talon tsi awd
Will the ecu work for my 91 tsi 5 speed?
91 tsi is offline   Reply With Quote
Old 07-14-2010   #5
I believe so due to this being a pre 92.5
Old 07-14-2010   #6
Thats cool, just get the measurements.
Old 07-14-2010   #7
Also forgot to add the Headlights that i resurfaced and look awesome. and come with or can come without HIDs with all of the wiring. (currently can give a demo of them working.)
Added to the OP.
Old 07-14-2010   #8
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
What color is the bov?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-14-2010   #9
Red. No scratches on it, and i can cut off the flange if you want it to weld onto some piping. (the fmic piping is really small like 2" so i dont think anyone will take that)
Old 07-14-2010   #10
What kind of oil pressure gauge is it?
Old 07-14-2010   #11
Autometer Ultralite and the Boost gauge is a prosport eletric with the opening ceromony.
Old 07-14-2010   #12
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Those lights are sexy!
and that ECU will work in any 91+
Its just the 90s you have to switch the two pins (6 and 14?) Something like that.
-Colin
Old 07-14-2010   #13
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I may want those headlights, with the HID kit, and should send some measurements and pics of he fmic core to hebert2190@gmail.com, thanks tom.
Old 07-14-2010   #14
DaltonDSM
Drives: 98 eclipse GS-T
wanna get me a price on the front bumper and is it cracked or anything? also send me a price for the headlights and hid kit. thanks
DaltonDSM is offline   Reply With Quote
Old 07-14-2010   #15
The Headlights and HIDs im putting up for $60 for the whole shibang.
Front bumper ill give to you for $35. Its in good shape. just could use some paint (the car was painted before i got it and was a very crappy paint job. they didnt rough up the under coating which is gloss black. so the paint is chipping here and there, but i dont think the bumper was cut at all. Ill verify this when i get home.
Old 07-14-2010   #16
91 tsi
do you a number I can call you? I would like to see if its possible to come get ECU this afternoon.
Old 07-14-2010   #17
Ok guys, i hate to do this, but it seems there is going to be a problem with the HIDs.
The problem is that 4 of you so far want them tonight and i only have one set. So instead of raising the price and making a bidding war. We will do this.
The guy who wants the most parts (money wise) will get them.
So far the current high bidder is:
Dalton DSM with a Front bumper and the HIDs/headlights.
Mainly this is just so that i dont have 4 people heading over at the same time and then complaining about how when they got there i didnt have the parts.
Old 07-14-2010   #18
92pearltt
Drives: 91 fwd stealth tt/ 99 SL
HOw much for the roller?
1994 RT/TT - Stockish for now ;)
1991 RT FWD TT - Race car work in progress
http://i110.photobucket.com/albums/n..._3110121_o.jpg
92pearltt is offline   Reply With Quote
Old 07-14-2010   #19
Depends on what you want with it?
Old 07-14-2010   #20
How much do you want for that sturdy work bench you got there?
