Old 07-24-2010   #1
Galant409VR$
Galant409VR$'s Avatar
Drives: 1991 Mitsubishi Galant VR4 409/2000
tdo5 turbo size
OK I know this question has been asked before but I have a tdo5 turbo I know its a 16g but what size 16g is it...? How do you tell if its a small or big 16g?
Galant409VR$ is offline   Reply With Quote
Old 07-24-2010   #2
CarPsyco84
CarPsyco84's Avatar
Re: tdo5 turbo size
TD05 is the part number for the middle section and turbine side of the turbo. To which a bunch of different compressors can be attached to. Stock 14b is a TD05 also, all the way up to a 20g is common on a TD05... The only way to tell a small 16g compressor from a big 16g compressor is to see if the wheel has uneven blade heights.(I forgot the Technical term). A small 16g looks like the 14b where all the fins look the same, a B16g has alternating fins. An evo III 16g is a B16g compressor with better exhaust housing and O2 housing.
-When in doubt, Moar RPM.
Old 07-24-2010   #3
Re: tdo5 turbo size
Actually i believe you are wrong there sir. A small 16g has uneven blades. The 14b is the only td05 that has the even blades.
Old 07-24-2010   #4
Galant409VR$
Re: tdo5 turbo size
the compresor housing has this on its 9810141004917805200Witch I was told the 5200 is a small 16gIt has a stamp on the compresor and turbo housings that say TRE does that mean the turbo I have was upgraded by TRE?</p></p>
Old 07-28-2010   #5
Gravy
Who's this guy?
Re: tdo5 turbo size
The problem you can run into with this "Number" idea is it turbo can be bored out. You could end up doing what i did, running the number on a turbo for sale in need of a rebuild. Buy the turbo and the wheel at the same time. Wheel comes in and you go to put it on the turbo.... and you can fit your finger along the side of the comp housing and turbine fins.
Best way i've found is to remove the top cover and measure the inducer and exducer diameter if you can.
Old 07-24-2010   #6
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: tdo5 turbo size
Find the serial number, and match it to one of these-
14B
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G
49178-01520
49178-05200
Big 16G
49178-01420
Evo I Big 16G
49178-01450
Evo II Big 16G
49178-01460
Evo III Big 16G
49178-01470
