Old 08-08-2010   #1
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
maf translator
well i installed my new maf translator and gm maf in blow thru set up in my 90 talon today,
i zeroed out everything and started my car up, it idled super high so i turned down the idle alll the way but it was still at 1.5-2k rpms so i turned the base map knob one click lean and it started idling perfect, only prob is im scared that is lean now since i dont have a wideband YET to fix this issue i turned the mid and high one click rich and it runs great and fast no fuel cut, im just wondering what you guys think, if im safe or not, and people have tuned by looking at timing and knock, can anyone tell me what good timing is and how much knock is ok... thanks in advance
Old 08-09-2010   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: maf translator
Why don't you have a datalogger yet? Or do you and you're not using it?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 08-09-2010   #3
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
i have a logger but my battery on my laptopwont hold a chage so thats why its not working right now
Old 08-09-2010   #4
Re: maf translator
Get that thing dyno-tuned so you can forget all your worries At the very least datalog that thing.
Old 08-09-2010   #5
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
I went too order a battery for my laptop and they was 90 freaking dollars! Soo maybe i will look for a palm lol, and do the idle speed screws go bad? I think mine might be because it's turned all the way down and it's at 1k-900 rpm idle little too high for my liking
Old 08-09-2010   #6
Re: maf translator
The rubber o-ring seal could be old, cracked, and leaking. I've pulled some out of 1G's that just crumble apart in my hand they're so old and brittle.
Old 08-09-2010   #7
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
Where should I look for one of them?
Old 08-09-2010   #8
Re: maf translator
Dealership...they're about a dollar.
Old 08-09-2010   #9
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
Lol should have known, gonna have to dig deep for that chunk of change! Lol
Old 08-09-2010   #10
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
Is there a specal trick to getting this thing out? Mine won't come out
Old 08-09-2010   #11
Re: maf translator
If it's driving fine right now, I wouldn't do anything until you can check the tuning on it. And don't boost it until you do.
Old 08-09-2010   #12
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
Ok sounds good but this idle screw and tricks to getting it out?
Old 08-09-2010   #13
19TsiAwd90
19TsiAwd90's Avatar
Re: maf translator
resolved!!!
Old 08-13-2010   #14
CarPsyco84
CarPsyco84's Avatar
Re: maf translator
yeah, the trick is too boost leak test it, then it will blow it right out of there when you unscrew it. when it comes to knock on the logger, a low number is good, 0-2 is considered ideal, if your getting more than 2 your running too much something, (timing/boost/too lean).
-When in doubt, Moar RPM.
Old 08-13-2010   #15
Re: maf translator
^We get it, you know about cars, but this was resolved like 3 days ago.
