Old 09-13-2010   #1
Wideband wiring..
So, my wideband has been acting weird lately. Stuck around 14.6-14.8..nothing else. Doesn't behave like it should. Problem is, it's a FJO wideband, wired into the EMS to monitor/adjust for different gas mixes on e-fuel. My issue is it's a older FJO. CWC0002 I believe. The sensor does't use the typical audi/vw plug. it's a square plug. I was wondering, could I cut the pigtail off on the wideband side, get a VW style plug, and then use bosch/NTK sensors from now on? Any thoughts?
Old 09-13-2010   #2
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Re: Wideband wiring..
Older FJO wideband units should use a NTK L1H1 sensor, which is an oem Honda sensor if what I've read is correct.
Jungy is offline   Reply With Quote
Old 09-13-2010   #3
anyone else have info on this?
Old 09-13-2010   #4
Jungy
Jungy's Avatar
http://www.supraforums.com/forum/sho...d.php?t=259361
Old 09-15-2010   #5
So, I need to go to NAPA and get a Honda sensor? wtf.. this one? part number: 36531-P07-003..?
