Old 09-23-2010   #1
Cammaxon
Brian Spilner called...
Cammaxon's Avatar
Rebuilding my Trans, what to order?
I just got off the phone with Jack from Jacks transmissions, I have a pretty good idea what i'm going to get but wanted mitsustyle input
Welded center diff for $50?
orrr
4 spider for $399?
I have heard many people complaining about how crappy it is to turn with a welded center diff, I refuse to stick with the 2-spider, and the 4-spider is $350 more than having jack weld mine up. HONEST opinions.
Stock 1st gear with new synchro?
orrr
Evo 3 double synchro and evo 3 input shaft for $319
I wan't to rev my lime green spilner mobile to 8000k rpm, launch it like Apollo 11, all day long no problems.... and my goal is for 500whp (up a solid 100 from current)
Which brings me to clutch disk, price isnt a big deal they are all within $20
6-puck sprung? (my choice unless u can convince me otherwise)
6-puck solid?
Street disk?
The order goes through tomorrow so w/b asap!
I Like Cheese
Old 09-23-2010   #2
Re: Rebuilding my Trans, what to order?
Unless this is a drag car, I would always recommend 4-spider. After that, I'd say just get a stock rebuild/refresh. That's all I ever ran. Stock rebuild (stage 1) with a 4-spider.
As for clutch, most single disc setups will drag above 8k RPM's which may affect your high RPM shifting. Not much you can do for that as far as I know. What clutch are you running, and whats your setup and goals? I really liked me ACT2900 PP / Clutchnet sprung 6puck bastardized setup.
Old 09-24-2010   #3
Agree with B-man, although I never really minded my welded diff. either.
I ran a TRE stg. 3/2.5 (they changed it since i bought mine), I absolutely loved it the best DSM trans I have driven, the higher RPM you revved it the smoother it was.
I wouldn't set my heart on a 8k RPM limit, although if you are shooting for 500whp you might/should get there, however focus on where you make power.
Clutch setup, I have read good things for people using a ACT PP with clutchnet disk, it seems to be the way for single disk setups. If you can go twin, i say go twin.
I'd say stg. 1 w/4 spider and a twin disk.
Old 09-24-2010   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Only input I can offer is if you go with a single disc clutch, get an unsprung 6 puck. I've broken 3 clutches due to the springs busting....
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-24-2010   #5
Which is exactly why people are using the Clutchnet disc, the springs are enclosed/contained better.
Old 09-24-2010   #6
What clutch have yuou been using? Those Ebay ones?
Old 09-24-2010   #7
123abc
123abc's Avatar
Drives: Loud cars
Stock, stage 2 xtd, stage 3 xtd. I'm really hard on my car when I drive, so I kind of find it hard to believe a disc that looks the same but costs twice as much is going to have lasted this long. Im still rocking out the same XTD stage 2 pressure plate and throw out bearing for around 3 years.
Old 09-24-2010   #8
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
XTD, aren't those chinese knock offs?
I and many others have had excellent luck with ACT 6 puck sprung. The only clutch to run in my opinion until you start making over 700hp dynojet.
Old 09-24-2010   #9
I had the TRE stage 3 with the 4 spider and loved it. I never had a problem shifting with either my competition stage 4 clutch or my twin disc.
I really liked my 4 spider, and I only got that because of people telling me it was better for a street car. I also really liked the longer first gear for drag racing. I'd probably go with a sprung 6 puck if it will hold your power/tq goals. My comp clutch stage 4 I remember holding to a little above 500 @ db with some nitrous. Maybe that clutch is worth looking into as they were super cheap when I bought mine.
Old 09-24-2010   #10
http://www.supramania.com/forums/sho...h-scam!/page17
Some interesting reading regarding XTD. Post 163 is a good one to jump ahead to.
Old 09-24-2010   #11
twack
It was a auto get over it
twack's Avatar
LOL heres a pic of Cams tranny, i had too!
I use an xtd stage 3 pressure plate and 6 puck sprung disc. I bought it seeing a few dsm buddies have luck with them and a some of the honda crowd. its cheap and i wont mind replacing it if it breaks. I wont go out and brag about them but i rock it and it works for me, I did recomend to Cam though that he get a ACT sprung 6 puck with his pressure plate.
Keep your head up cam. i would just wait a little while and shop around for someone selling a used built tranny with your $$$ goals.
Old 09-24-2010   #12
Just run it.
Old 09-24-2010   #13
Cammaxon
Cammaxon's Avatar
THanks for all the input im still trying to figure every thing out. I kinda really wanna buy tony Kellars stage 4 tre but he wont get back to me
I Like Cheese
Old 09-24-2010   #14
Cammaxon
Cammaxon's Avatar
but really, i've got $1500 maybe more if some one has a mint epic 2g awd tranny.
I Like Cheese
Old 09-24-2010   #15
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
go with something sprung for a clutch disk, I have an ACT unsprung 6 puc and a ACT HD pressure plate and I hate how harsh it is for street driving. As for shifting at 8k I rebuilt my tranny and shifts great at that rpm with a single disc. Either way have fun with it!
badinblack is offline   Reply With Quote
Old 09-25-2010   #16
with $1500, you mind as well jsut get it rebuilt by DB or shep, jacks or something. Halon knows what he's talking about. His car scooted down the track.
Old 09-25-2010   #17
Cammaxon
Cammaxon's Avatar
You cant get shit for $1500 from them that's gonna hold power and considering shipping is $200.... that brings it up to 17.
I Like Cheese
Old 09-25-2010   #18
For the millionth time, have DB take care of it! They have great relations with a semi-local tranny shop.
Old 09-25-2010   #19
http://dogboxracing.com/Transmissions-DSM-AWD.html
http://teamrip.com/DSM_AWD_STAGE1_REBUILD_SERVICE.html
http://www.jackstransmissions.com/co...-trans-rebuild
basic rebuilds aren't that spendy. You'll have to tack on 200-300 for a 4spider installed, then shipping. You'll be under 1500.
If you're on a tight budget, it's a cheap setup that'll hold some power. The other things that come on stage 43594 sure can be nice, but if you are on a tight budget, there is nothing wrong with a standard rebuild with a 4-spider.
Old 09-25-2010   #20
twack
twack's Avatar
the issue for cam is his core is pretty much worth less. the gears wore into the housing, and there is carnage everywhere. he would need a good core aswell, not just his rebuilt
