09-26-2010
#1
Found My WOT Exhaust Leak: Why?
***UPDATE**** RESOLVED: Really used and stretched ARPs were the cause of my headgasket failures. Head would lift at 30+ psi. I was running 37psi New studs fixed this issues***
Some Background:
Blew out my composite HG earlier this summer.
Replaced with another OEM
Week later a valley formed and peed coolant on t-belt side of cly. #1
I then replaced it with a Mitsu MLS, and had the head resurfaced.
2 weeks later, I start hearing an exhaust leak noise at WOT and High Load, CEL comes on for Knock.
Fixed a loose wastegate, and an exhaust leak. Still there. Pulled head today:
Evidence of Cylinder number 2 leaking combustion gas on the firewall and radiator side.
Black coloring on cylinder head, top and bottom of HG, and block. That area the headgasket when layed in a free state is bulging and has debris inbetween the layers.
I have been reusing standard ARPs that I got 3+ years ago, and have been retorqued many times.
Any idea why this happened?
09-26-2010
#2
Re: Found My WOT Exhaust Leak: Why?
This is your problem.
Originally Posted by Murlo26
#3
So they're most likely stretched? Wouldn't that affect all cylinders versus just one?
#4
I'll get some MAP/A1's I guess lol
#5
LOL even I said swap those fuckers out one-by-one and boom..problemo solved-o.
#6
some stretch more then others. There was a video on this, as well as testing arp's moly lube, the shit pro racer's use, and motor oil. How when we "torque" to 100 ft. lbs...it's not actually at 100, and such. You prolly just strained them all, and those for whatever reason have stretched and become weaker then the others.
#7
That's what she said.
Get one of those nice expensive head gaskets too. DSM owners are lucky that you can buy a gasket that makes o-ringing the block unnecessary.
09-26-2010
#8
is Nashty
Drives: Cyborg from Japan
MAP/A1's and a new MLS and you will be golden. About time you learn your lesson!
-1990 Mitsubishi Cyborg 4WD-
09-26-2010
#9
Drives: 2G DSM
Mitsu MLS are crap. There's only one MLS worth buying.
09-26-2010
#10
Why?
Perma-Torque?
#11
Why?
Perma-Torque?
It seems that perma-torque's are the type of headgasket that you do once, then forget about. That's the route I went. Although, my car hasn't run yet with it, many other seem to have great success with them. I have never heard one person say they are junk, while I have heard handfuls of people say that about the mitsu MLS. Again, this is just what I have heard.
Originally Posted by scheides
09-26-2010
#12
is Nashty
He is full of crap. There is nothing wrong with the mitsu mls.
09-26-2010
#13
Exact same problem I had on my evo8, I'd rather buy new OEM head bolts than re-use arps. New ARPs or get some L19's.
Originally Posted by turbotalon1g
09-26-2010
#14
I say OEM Mitsu headgasket, good new head studs and call it good.
Also, I'd take your head it and have it check for flatness, and possibly get a straight edge to check your block's flatness too.
Originally Posted by Tachyon
09-27-2010
#15
Yup. Head studs shouldn't be reused, period.
#16
A1's or L19's + Permatorque = done. It's been proven over and over.
09-27-2010
#17
I know about the greatness of MLS gaskets. I have used the Mitsu MLS before. The perma-torque is great, I know.
I already checked the block for flatness, it appears to have a .002" variance which should be within spec.
ARP does not manufacture 6-bolt L19s anymore.
A1/Map and a Mitsu or Fel-Pro MLS.
Then Bye Bye car!
#18
Why not save the funds and get a new set of regular ARP's?
#19
Has it been knock a lot and blew it? You might want to make sure the head and block are perfectly flat, or else it might keep blowing in that spot.
09-27-2010
#20
This doesn't knock lol. Thanks to your tune  Welll when it starts blowing out the headgasket it does!
(And yes, it has a new knock sensor torqued to spec)
