Old 11-05-2010   #1
awd laser
awd laser's Avatar
Drives: 93 TSI
somethings wrong with the fuel system!
I have a 92 laser rs, and last week while I was driving my bro and sis to school in the morning I noticed that when I stepped on the gas pedal lightly, the car's rpms would drop and it would start to stutter. But when I pressed a bit harder the rpms went up it would be just fine. Except when the rpms were around 2k and lower, and when I stepped on the accelerator just a bit to maintain my speed the car would stutter again. Later on that day around noon while driving in St. Paul, the car all of a sudden started to stutter and died on me! I was going about 35 in 4th gear. I tried to start it up again but right when it started, the engine stuttered and died. Also when this happened, while the key was in the on position, the boost gauge's needle was at -7, then later on it went to 0psi and started jumping around. This made me think it was an electrical problem, also at this time we can hear the fuel pump relay start clicking abnormaly from behind my cd player. A week later while the car was sittin at the house because afer we towed it, I put in a used Fuel pump relay and its doing a little bit better now. But the problem now, is that when I start the car everything is normal, except when I press the gas pedal lightly, the rpms would drop and soon the car would die. Please help me out here! Also the check engine light is on and i do not have a data logger. Thanks for reading hope you guys can help me out here and sorry for the long essay there, just trying to throw out all the info about what happened.
Old 11-05-2010   #2
awd laser
awd laser's Avatar
Drives: 93 TSI
Re: somethings wrong with the fuel system!
Also the car is all stock! 14b turbo, 18 years old and never been touched!
Old 11-05-2010   #3
To check your CEL go to VFAQ and click on DSM>Electrical>Retrieving Diagnostic Error Codes 1G. Follow those directions. Also, the stock boost gauges are crap, they don't even read actual boost, so don't even bother looking at that thing.
Old 11-05-2010   #4
awd laser
awd laser's Avatar
Drives: 93 TSI
do u think it could be a bad fuel pump though?
Old 11-05-2010   #5
It could be, there aren't many CEL's for 1g's so when there is one, it is usually fairly important. Check the code and report back.
Old 11-05-2010   #6
awd laser
awd laser's Avatar
Drives: 93 TSI
is there a way to find it out without a data logger?
Old 11-05-2010   #7
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
sounds like multiple issues maybe, bad maf possibly too, seeings how the stock crap boost gauge uses the maf to "calculate" your boost and you said it was jumping around leading me to maybe think it could be a bad connection or bad maf or possibly even ecu
Originally Posted by 311evo
Old 11-05-2010   #8
Maybe a bad throttle position sensor. Hard to say without knowing what the check engine light is for.
Old 11-05-2010   #9
I'll copy paste them for you since you didn't want to follow the directions I laid out:
From VFAQ:
There will be a diagnostic code inside the ECU (Electronic Control Unit) if and only if the 'Check Engine' light on the lower left portion of the dash is illuminated. To get the code that the ECU is reporting follow these steps:
  1. Locate the engine diagnostic test terminal located at the top of the drivers side kick panel (next to the fuse box). See illustration[/FONT]
    You will want to count the pulses that are produced from the MPI terminal. The easiest way I found was to buy a 12v electric buzzer (Radio Shack #273-055 $2.49) and attach its leads to the terminal connector, then just listen for the pulses. You can also use an analog voltmeter and count the pulses displayed.
    There are two types of pulses we are looking for "long" and "short". We are looking for a pattern where we have a series of long pulses (1 or more) and a series of short pulses (1 or more), then more long pulses. The codes always start with a long pulse and will finish with a short pulse. So start counting with the first long pulse after a short one. Count until you hear a long pulse after a short one again. NOTE: If you hear a constant "buzz", then your ECU is reporting that there is a problem with the ECU itself, if you hear only short pulses, there is no error code to report (i.e. normal state).
  2. Lets say we write down: S-S-L-L-S-S-S-L-L. We know that we start and stop with a long pulse after a short one. So that happens at two places in our example. At the 2nd/3rd pulse set, and at the 7th/8th pulse set. The pulses between those two are what we want: L-L-S-S-S.
  3. Now that you have the code, we need a code number. For every long pulse count it as a 10, and every short pulse counts as 1. So in our example, it is 10-10-1-1-1. Add them up and that is your code number, in our example 23.
  4. Find your code number below and the resulting diagnostic item.
Self-Diagnosis Codes for 1.8L and 2.0L Engines Code #Diagnostic Item ConstantECU11O2 sensor
12
Volume air flow sensor
13
Intake air temperature sensor
14 Throttle position sensor
15 (1.8L only)
Idle speed control motor position sensor
21 Engine coolant temperature sensor
22
Crankshaft position sensor
23 Camshaft position sensor
24
Vehicle speed sensor
25 Barometric pressure sensor
31 (2.0L Only)
Knock sensor (turbo only)
36 (1.8L Only)
Ignition timing adjustment signal
41 Injector
42 Fuel pump
43 EGR (Ca. only)
44 (2.0L Only)
Ignition coil, ignition power transistor unit short pulses only normal state
Old 11-05-2010   #10
awd laser
awd laser's Avatar
Drives: 93 TSI
we took a look at the ecu and doesnt look like anythings wrong because the one things (sorry forgot the name of it) arent' leaking. But I'll get my video camera and record the car start up and everything so it'll be a lot easier for you guys to understand whats going on.
Old 11-05-2010   #11
It sounds like you need to:
CHECK WHAT THE CEL IS FOR!!!!!!!!!!!!!!!!11
Old 11-05-2010   #12
awd laser
awd laser's Avatar
Drives: 93 TSI
thanks, i will try it out and report back
Old 11-05-2010   #13
awd laser
awd laser's Avatar
Drives: 93 TSI
well i checked the CEL, and its giving me a constant code meaning theres somethin with the ECU. Do you guys think if I switched it with a eprom ecu that it would do something with the car? or will it run normally? Because my uncle has 2 eprom ecu's in his garage from his old GSX, so by switching it, would my car still be good? BTW im only 16 and im a noobie so sorry for all the Q's, jus trying to learn some stuff about these cars.
Old 11-05-2010   #14
If your Uncle's ECU's are stock, and so is your car, you shouldn't have a problem. Give it a try.
Old 11-05-2010   #15
awd laser
awd laser's Avatar
Drives: 93 TSI
okay i will switch it out next monday and see how it goes then report back.
Old 11-08-2010   #16
awd laser
awd laser's Avatar
Drives: 93 TSI
okay i slipped in 2 different ECU's and the car is still running the same. Any advice on where to go from here?
Old 11-08-2010   #17
Did you check what the CEL was yet? I don't understand what "a constant code" means. The reader should be able to tell you something about why the light is on.
Old 11-08-2010   #18
awd laser
awd laser's Avatar
Drives: 93 TSI
a constant buzzing code which is what i got, means the ECU is trying to say there's something wrong with it itself. So since my uncle had 2 eprom ecu's layin in his garage i threw them on an the car was still acting the same so idk what to do now. The problem is that when i would step on the gas pedal lightly at rpms lower than 2k, the car would stutter and the rpms would drop then soon jus die!
Old 11-08-2010   #19
With the new ECU's, the CEL is still on or not?
Old 11-08-2010   #20
Did you check the code once the new ECU's were in?
