Old 11-10-2010   #1
travail
travail's Avatar
Drives: EV0 8
Question inline fuel pump booster
How many of you guy's run one. I was thinking of doing this because it's cheaper the getting a double pumper. What do you think.
travail is offline   Reply With Quote
Old 11-10-2010   #2
mlomker
*Resting In Peace*
mlomker's Avatar
Re: inline fuel pump booster
You mean an inline pump or a Boost-A-Pump? If you're on E85 then an inline Bosch 044 will get you a long way.
Old 11-10-2010   #3
travail
travail's Avatar
Drives: EV0 8
Sorry I mean a inline pump with my in tank walbro.
Old 11-10-2010   #4
How's your car running anyways? Just run a boost-a-pump on a single walbro in tank. Jake (311evo) hit 530whp at DB with this setup with room to spare.
Old 11-10-2010   #5
travail
travail's Avatar
Drives: EV0 8
I had to put in all new bearing and a new 100mm crankshaft and now I just waiting on getting a clutch. Iam running a single walbro in tank thats why I was asking about the booster pump. Shane at DB side I would run out of fuel at about 450 to 470 with 1000cc injector and I want to be close to 550 to 600 and that I need a inline pump with mt in tank walbro or double pumper.
Old 11-10-2010   #6
Well, I would run a modded single pump (shane can show you this) with a BAP, hands down. It worked on many other cars and it will work on yours. That should get you to 550whp at least and if you make more than that then worry about the dual pump setup or an inline or something. If you are 130% sure it will hit 600whp on shane's dyno then you might need more.
Wait, are we talking about 1.0CF or shootout numbers? What turbo are you running? Your 470whp sounds like shootout numbers....if that is the case then just go for the single as stated.
Old 11-10-2010   #7
travail
travail's Avatar
Drives: EV0 8
My set up is
EAGLE 2.3 STROKER W/ WIESCO PISTONS & EAGLE RODS EAGLE CRANK.
ARP HARDWARE THROUGHOUT THE WHOLE ENGINE
TOP MOUNT GT35R
3 inch RNR FULL EXHUAST SYSTEM
SPEARCO FRONT MOUT INTERCOOLER WITH 2.5" INTERCOOLERPIPING..
DLI IGNITION & C.O.P SETUP
AFTERMARKET INTAKE MANIFOLD W/ 70mm ACUFAB THROTTLE BODY..
CROWER VALVE SPRINGS AND REATIANERS
3 ANGLE VALVE JOB
1MM O/S SS VALVES
AEM ENGINE MANAGEMENT
EXEDY PRESSURE PLAT W/ CLUTCH NET 4-PUCK CLUTCH
ADJUSTABLE VENOM CAM GEARS
HKS 280 CAMS
1000cc injector
In tank walbro
Old 11-10-2010   #8
A Boost-A-Pump is not an inline booster. It's a voltage booster/regulator. Some guys run that, some guys put a Walbro GSL392 inline or a Bosch 044 inline. Some guys run a Walbro intake plus a Bosch 044 or GSL392 outside of the tank, but with a pickup intank in parallel.
Old 11-10-2010   #9
You will need bigger injectors. With 1 intank Walbro with stock wiring to the fuel pump on E85 you would probably max them around 420awhp on my dyno. With good fuel pressure with 2 pumps or whatever they might be able to handle another 10-30awhp.
Old 11-10-2010   #10
Like was said, there's a few options. BAP will just increase voltage to the single pump, causing it to flow more. Adding an inline external pump (dual pump in series) is another way t get more fuel to the injectors. Not sure about evo's, but twin intank pumps in parrallel is another option possibly. Pick your poison
Old 11-10-2010   #11
mlomker
*Resting In Peace*
mlomker's Avatar
He was thinking that an inline would be cheaper but it isn't. You need a large inline pump to get anywhere near the flow of two Walbros in parallel. A $190 Bosch vs a $90 Walbro.
In addition to larger injectors he'll need an afpr setup for most dual pump configurations--the only exception would be if he ran the second pump of an in-tank double pump on a Hobbs switch.
Old 11-10-2010   #12
travail
travail's Avatar
Drives: EV0 8
So I should just get the buschur double pumper and 1600cc injector then to make close to the power I would like.
Old 11-10-2010   #13
Avoid the 1600s like the plague with the AEM.
Old 11-10-2010   #14
travail
travail's Avatar
Drives: EV0 8
What should I use then?
Old 12-13-2010   #15
spoolin d dub
spoolin d dub's Avatar
Drives: 1990 eagle talon tsi awd
Disregard the comment on 1600 injectors and AEM. It's certain brands of injectors (like bosch 1600's) that are hard to tune on the AEM. You can run Deatschwerks 1600's with no problem and they are ethanol and methanol compatible.
http://www.deatschwerks.com/catalog/...roducts_id=102
and the boost-a-pump with you setup will safely get you to your goals.
spoolin d dub is offline   Reply With Quote
Old 11-10-2010   #16
I don't know what a Buschur Double Pumper is but it sounds kinda scary.
Again I don't know about evo's much, but can you just do something similar to this in an evo?
http://mitsustyle.com/forums/showthr...ht=dual+walbro
Old 11-10-2010   #17
You can't do the home brew setup on an Evo or 2G, not enough room and they run split tanks with a siphon system.
Old 11-10-2010   #18
Welp, then sounds like a mustache double pumping might be the answer to your prayers.
Old 11-10-2010   #19
travail
travail's Avatar
Drives: EV0 8
Here what it is
