Old 12-30-2010   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Leaking freeze plug, and bare wire?
So I'm in the middle of a head replacement and there are a few things I've found that are concerning me and thought i'd get a second opinion.
First, looking at the back of the block, it seems like one of the freeze plugs are leaking. There is a fluid stain trail down the back of the block, coming from it. I should replace this, right? Should I replace all of them? How often do they leak? Best way to knock it out, is it hard?
Pics:
Second, There is a bare yellow wire on the harness that goes to the alternator plug. Any idea what this is for?
Pic:
Thanks for the help!
Style's automotive engineer
Old 12-30-2010   #2
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Leaking freeze plug, and bare wire?
I think the wire is for the power steering. The frost plugs are thicker than they look. You have to pretty much wreck them to get em out. Easy to replace though. If the others are not leaking I would not worry to much.
Old 12-30-2010   #3
s1ngletracker
Drives: A BMW
I'm actually just gonna grab a block heater and stick that in that spot daily driver yo!
Old 12-30-2010   #4
s1ngletracker
Drives: A BMW
where does the yellow wire go to PS? I don't see a plug anywhere or anything...
Old 12-30-2010   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
There is a male single post connector on the pump itself. (almost looks like a vacuum port)
Old 12-30-2010   #6
Looks like the coolant tube running from the waterpump needs a new seal too.
Old 12-30-2010   #7
s1ngletracker
Drives: A BMW
yeah, it just got one with the new water pump. Still looks a little wet there, but it hasn't run yet.
Old 12-30-2010   #8
http://www.permatex.com/products/aut...one_Gasket.htm
I used this with my water pipe, it worked well.
Old 12-31-2010   #9
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
That looks like a starter wire to me, looks to far down to be a P/S wire, Is there anything not working or acting funny on the car?
"Call amberlamps"
Spikesoftail is offline   Reply With Quote
Old 12-31-2010   #10
s1ngletracker
Drives: A BMW
it is a p/s wire. The starter is on the opposite corner of the engine.
I was going to put the block heater in the one that was leaking, but there wasn't enough clearance inside for the heating element. So I punched another one out, and put a new plug in the leaking location.
coming together!
