Old 01-02-2011   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
Mostly Stock 2g Eclipse Parts. 7 bolt. 4g63/4g64's. some body parts
I Have A Couple Of Parts For Sale after the years of building my eclipse. Most of these parts are interchangable between the 2.0 turbo (4g63) and the 2.4l n/a motor (4g64) from 95-99
2g 4g64 sohc head (complete)
A Set (2) Of 245/50/R16 Kumho's with 50+ percent left of tread left
4g63 intake manifold
4g63 exhaust manifold
4g64 intake
spare tire
bright red right door (complete without door panel)
Transmission cooler (auto)
4g63 fuel rail
2wd gas tank (with fuel pump)
Drivers cloth seat (passenger mounting bracket broke off. ill give it to you with the drivers seat)
(x2) o2 housing (one is custom made. one is for the stock turbo)
(x2) automatic FWD starters
4g64 wiring harness
bright red rear hatch (complete with some panels missing)
2g 4g64 intake manifold and throttle body (complete)
4g64 header/exhaust manifold
rear cloth seats
n/a radiator
(2 sets) radiator fans
(x2) alternators
(x3) a/c compressors
(x2) power steering pumps
4g63 head gasket (felpro, Never Used)
(x2) 2g ecu (not eeprom)
2g tcu (auto)
Automatic tachometer with 160k on it
4g64 water pump
4g64 thermostat housing that bolts to the head
4g64 oil filter housing
a/c compressor bracket
Automatic brake petal
Stock radio amp that is placed under the drivers seat
4g64 downpipe
charcoal canister
4g64 coil pick
4g63 coil pack
cruise control module with cable
2wd front left brake caliper
(x2) a/c condenser
Just throw me an offer on a part and ill let you know if it is negotiable or not.
couple of parts that i cant think of right now.. but just let me know what you need and ill let you know if i have it.
The Car In The Picture Is Just For Reference Of The Color Of The Door And Hatch.. The Car Is Junked.
Call/Text/PM Justin @ 3203338677
Name:	update 8-10 (16).jpg
ID:	11193   Click image for larger version
Name:	update 8-10 (4).JPG
ID:	11194   Click image for larger version
Name:	update 8-10 (5).JPG
Name:	update 8-10 (6).JPG
ID:	11196   Click image for larger version
Name:	update 8-10 (3).JPG
SpyderGSX07 is offline   Reply With Quote
Old 01-17-2011   #2
SpyderGSX07
Re: Mostly Stock 2g Eclipse Parts. 7 bolt. 4g63/4g64's. some body parts
Bump
