Old 04-06-2011   #1
Another nerd question
On all new laptops these days, Windows 7 64-bit seems to be standard. Is there a way to convert it back to 32-bit? We're running into some compatibility issues here at work. Thanks.
Old 04-06-2011   #2
Re: Another nerd question
Your only option is to reinstall using the 32-bit version.
You also can not perform an upgrade between them either, such as going from Vista 32-bit to 7 64-bit.
Old 04-06-2011   #3
So you'd have to locate a licensed copy of 7 32-bit I take it. Is that even available new anymore?
Old 04-06-2011   #4
daoshao
Drives: 2g gst
Yes, it is available new. Go to Microcenter in St.lous park. The 32 bit win 7 is tied to the 32 bit processor. The 64 bit version is tied to the 64 bit processor.
daoshao is offline   Reply With Quote
Old 04-06-2011   #5
Vista came with 32-bit and 64-bit DVDs in the same case. All you pay for is the license, and it works for both flavors.
Originally Posted by daoshao View Post
Yes, it is available new. The 32 bit win 7 is tied to the 32 bit processor. The 64 bit version is tied to the 64 bit processor. I didn't know you could install the 32 bit 7 version on a 64bit machine.
A 64-bit processor runs 32-bit applications, but not the other way around.
Old 04-06-2011   #6
daoshao
Drives: 2g gst
Hmm..interesting. Never tried it. Might have to give it a whirl on my test station.
Old 04-06-2011   #7
64-bit processors were mainstream long before 64-bit operating systems were used by consumers.
Old 04-06-2011   #8
Yes, you can get Windows 7 in both 32 bit and 64 bit at most computer stores. I run a mixed environment here at work.
Old 04-06-2011   #9
So if my customer purchased their laptop preloaded with W7, it would have backup copies of 32 and 64 in the case? Or is that only buying the full program from say Microcenter?
Old 04-06-2011   #10
It should have reinstallation media for either one. If it doesn't they should be able to get it from the laptop manufacturer. The same license key will work for both 32-bit and 64-bit.
Old 04-06-2011   #11
That's the info I was looking for, thanks!
Old 04-06-2011   #12
viridionplague
have you tried running your programs in "compatibility mode" set for windows xp service pack 2??
to convert back to 32 bit you would have to reformat the computer so you need a disk.
Old 04-06-2011   #13
This is for a customer of ours in Canada. We've got a team of engineers across the building, but I knew I could get the right answer here faster.
Old 04-06-2011   #14
cmspaz
Walls need hugs too
cmspaz's Avatar
Sometimes you even need to go back to win98 compatibility mode to get stuff to work in certain instances. I've seen that with stuff released within the past two years even...
Originally Posted by Trogdor
Old 04-06-2011   #15
People need to stop creating shit software.
