Old 04-19-2011   #1
ManiacMotorsports
TOO MANY PROJECTS!!!
ManiacMotorsports's Avatar
GTA Champion!
Drives: 1991 Eagle Talon TSI/AWD, 1992 TSI/AWD, 1998 Eclipse GSX, 1989 IROC-Z, 1998 Cherokee, and a few more
1g cruise control...Can't get it to work
So I'm dealing with a car that had the cruise deleted. Here is what I have done/found so far.
1: I put a cruise control unit in it... nothing, little orange light comes on on stick that was it...
2: Twotalons suggested checking that the clutch switch was being engaged...checked this to reveal it had been removed completely along with the brake pedal being switched out for a 2 prong unit... so I replaced them both... (with used parts) still nothing.... little orange light thats it....
3: I replaced the multifunction switch assembly, no change... still no cruise...
Probably going to take the drive to down and buy a unit from TwoTalons but any suggestions would be appreciated....
Thanks,
-Travis
ManiacMotorsports is offline   Reply With Quote
Old 04-19-2011   #2
Re: 1g cruise control...Can't get it to work
Pretty simple, but have you checked the related fuses? You should have a cruise light come on on the dash, the orange on the stalk is just paint.
Old 04-19-2011   #3
ManiacMotorsports
GTA Champion!
Well I have in general looked over my fuses but I can't find anything specified toward cruise and I don't have an owners manual
Old 04-19-2011   #4
Another thing might be the vacuum line going to the control unit on the firewall.
Old 04-19-2011   #5
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
check all connections, if i hit a bump some times mine will quit working for a bit and then come back on
Originally Posted by 311evo
Old 04-19-2011   #6
ManiacMotorsports
GTA Champion!
found the problem, turns out the guy that eliminated the cruise originally took out everything, the brain box under the dash was removed.
