Old 10-15-2011   #1
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
97 GSX/ Borg s259 ett/ e73 dyno results
Finally got her on the dyno and not one thing went wrong!!! My e85 was tested and it turned out to be e73. Would have made my goal of 500 awhp but the clutch was slipping since it is not broke in yet. But in all I was very happy with the results!!! Enjoy!!!
480 awhp/ 375 ft lbs
Made 561 awhp on the dyno jet setting.
http://youtu.be/_V9kEcnV5dU
http://www.youtube.com/watch?v=_V9kEcnV5dU&hd=1
Old 10-15-2011   #2
b00sted_spyder
Re: 97 GSX/ Borg s259 ett/ e73 dyno results
Very nice! What PSI were you running?
Old 10-15-2011   #3
1G_DSM
1G_DSM's Avatar
Dang, congrats. I'm sure you'll break 500 next time.
Old 10-16-2011   #4
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Nice, have fun with it now before the snow flys!
Old 10-16-2011   #5
Full mod list please! Glad it worked out for ya, your car looks like it's running great!
Pffft, 480 is weak souce...
...my X made 481
Seriously though, congrats! Hopefully the clutch is alright after all that beating, get it fully broken in and go have some fun with it! Looks like a really nice car!
Old 10-16-2011   #6
That is some power curve! It doesn't fall off at all. Must be super fun!
Old 10-16-2011   #7
Wow, sweet numbers!
Old 10-16-2011   #8
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Here is the dyno sheet, it wouldn't let me post it last night for some reason but here it is.
Here is a link to my mods:
http://www.dsmtuners.com/forums/memb...ze-109069.html
You should be able to view it even if your not a member but if not, just let me know.
Old 10-16-2011   #9
Congrats, how much boost?
Sounds like a nice ride.
Old 10-16-2011   #10
I don't see dyno sheet. Looks like great power for a pretty basic setup. What did it take to get the IX pistons onto the 6-bolt rods?
Old 10-16-2011   #11
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
It was at 30 psi and it is the same modification to the rods to get the 2g pistons on the 6 bolt rods.
Here is the dyno sheet, wouldn't let me upload it before.
Old 10-16-2011   #12
GsXkingGsX
GsXkingGsX's Avatar
Drives: 1997 Eclipse GSX
Send a message via Yahoo to GsXkingGsX
Very nice man. I'm about to pick up a S256. I'm shooting for about 450.
'97 Eclipse GSX
GsXkingGsX is offline   Reply With Quote
Old 10-16-2011   #13
Maybe Shane can chime in, but that appears to spool similar to a 35r sized turbo.
That powerband is sweet congrats man, go run some 10s!!
Old 10-16-2011   #14
I was thinking about this and found an old dyno plot from shane/mara's 'project salt collector'
http://www.mitsustyle.com/forums/showthread.php?t=18245
Overlay shows mara's SC61 outspooling this thing but the BW turbo kicks butt up top!
Old 10-17-2011   #15
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Thanks for the overlay!!! Yes I bet the t4 housing is slowing the spool down alot but helps out with the higher RPM as it doesn't choke out. I think if it had the smaller housing, it wouldn't be able to hold that power all the way to 9k like it does.
Old 10-17-2011   #16
The bad topend on Mara's SC61 had to do with the intake pipe in front of the turbo. This is after fixing the intake problem and some other changes( http://www.mitsustyle.com/forums/att...2&d=1285892300 ), but a better comparison of the turbo potential, it wasn't the SC61s fault for the old bad powerband.
His divided T4 housing should help spoolup a decent amount, but his exhaust manifold runners are on the big side and his cam has no low end, so those are probably hurting his spool up. You can have the same turbo on the same size motor spool 1500 RPMs different from one car to another depending on things like exhaust manifold, cams, intake manifold, cam gear settings, fuel used, etc.
His clutch slipped bad enough for the RPMs to shoot to revlimiter a couple times, so we had to keep the boost/power down some.
Old 10-17-2011   #17
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Thanks for the info Shane and again thanks on the killer tune. I may swap the cams out for some kelford 272's and see if I can pull some vacuum/gain some spool time. Next time the clutch should be broke in so we can push the turbo to it's limits!!! And I don't feel that the spool is too bad considering it pulls so hard all the way to 9k without peeling off.
Old 10-16-2011   #18
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Ya it may be a little slower than usual due to the t4 housing it is in, it's in a .84 AR divided t4 housing. Don't ask me why but the previous owner had it made for it.
Old 10-16-2011   #19
GsXkingGsX
GsXkingGsX's Avatar
Damn that sucks. I know a friend of mine uses a mitsu flanged S259
'97 Eclipse GSX
Old 10-16-2011   #20
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Ya it does suck but I guess I know the housing wont choke the turbo down. I am also thinking about swapping an HX40 pro with a divided t4 housing and see how they compare.
