Old 04-01-2012   #1
90* Oil Drain
Do you guys think that a 90 degree fitting on the bottom of the oil return is too much angle? A 90 degree works so much better for my setup. Every kit out there comes with a 45 but I tried that and it doesn't work as well as the 90
1998 Spyder AWD
567hp
490tq
Old 04-01-2012   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: 90* Oil Drain
I'm using a 45° on my setup and it works great... I wouldn't think the 90° would flow as well as the 45° but I also don't think it would cause any problems. What setup are you running that a 90° would work better?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-01-2012   #3
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: 90* Oil Drain
I second this
2006 WW IX RS 396/404 - SOLD
Old 04-01-2012   #4
Re: 90* Oil Drain
Same setup I had last year. I tried the 45 and it just didn't seem to sit right.
1998 Spyder AWD
567hp
490tq
Old 04-02-2012   #5
mike55112
mike55112's Avatar
Drives: 04 evo
Re: 90* Oil Drain
As you remember with kevins setup, the oil drain seems pretty important. I wouldn't chance it with your luck with shit breaking.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 04-02-2012   #6
Re: 90* Oil Drain
It depends on the turbo. A ball bearing turbo doesn't use much oil, so a lesser oil return can work.
Old 04-02-2012   #7
Re: 90* Oil Drain
It's a FPDSM88 ball bearing. You think the -10 90 degree will be ok?
1998 Spyder AWD
567hp
490tq
Old 04-02-2012   #8
Re: 90* Oil Drain
Yes.
