Old 05-06-2012   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Project V8killa
So here it goes. I've been buying cars parts left and right and now seem to have found a shell I could be happy with building knowing it can be done right.
People that I want to thank so far since I've got back in. Jim(talonfiero). Thanks for getting me back and teaching me how to swap trans. Brad (celicabrad) knowledge and parts. Aaron(turbotalon1G) giving me a plan of how to build a car and just keep 1. Tom(blacktalontsi) for giving me a great deal on a car that is absolutely rust free and tons of dsm parts to boot.
And all of you on here that helped out and been over either buying parts or selling me some.
Enough of that on to the good stuff
I recently picked up a shell that came from Texas. Originally jungy had it did a few things like wire tuck, brakes, suspension ect. Then Tom bought it and now I own it. Car was purchased as a shell but had a ton of parts included
Ok so parts I already have
Exterior
Koni yellows w/eibach coil/springs
16" Rota slips
drilled rotors
2GB talon front bumper
2GB talon rear bumper
95 talon twist sides
ABS delete w/SS lines
3" v band down pipe
Custom front exit exhaust
Carbon fiber hood
Interior
DSM link v3
Aem wideband
Phantom gauges
Boost
Oil press
Water temp
Volt
Black interior
Door skins
Dash
Center council
Rear speaker covers
Door handles
Tenzo R seats
Engine
2.4 6 bolt shortblock
CP 87.5 9:1 pistons 22 wrist pins
Manley h beams w/22mm wrist (new style)
Kiggley main girdle
ARP main studs
L19 headstuds
Cometic MLS 87.5 headgasket
Turned down BS
1G head slight port
FP beehives
GCS 3 cams
OBX ramhorn t3 Manifold
Motor is at gosh will be gone through machined and assembled Pistons are still 3 weeks out
Fuel
Aeromotive fpr
Walbro 450 pump (new e85 design)
Kenne belle boost a pump
FIC 2150cc injectors
Stock rail with an fittings
680 small battery
FP non recirc with k&n filter
Things I still need to order
SD setup
Turbo? Still undecided but 6262 or bigger t3 with 3" v band
Magnus v5 intake
Send out my evo 1 trans to Tim Zimmer for some upgrades
southbend carbon Kevlar clutch holds 600 tq
Tial bov
Tires for slips
Carbon hood/hatch
ETS core
Custom 3" cooler piping
Thanks again Jugny and Tom for keeping a clean car clean and hope to have it up by proving grounds
Pics I hope privious owners dont mind
Ill add more pics and phots as i get the motor and parts in just waiting for the brown truck to show up so I can keep moving forward.
Old 05-07-2012   #2
blackawdtsi
Drives: 2G DSM
Re: Project V8killa
I love my Makita
Swap the Cometic for a Permatorque and get a real clutch. If CP hasn't made your pistons yet - seriously, talk to LaCroix Other than that, she'll move. Good luck!
Old 05-07-2012   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
I can't run q permatorque cause they only go to 87mm. I already ordered the CPs and they said a few weeks still. Not a biggie since gosh said he's 2 weeks out anyways. Zimmer swears up and down about the southbend do I'll give it a shot if it don't hold I'll go to a comp TD like you did.
Old 05-07-2012   #4
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Project V8killa
I actually have run one before on a 88mm over-bore custom job. It worked great. I even reused the gasket in my current 87mm 2.4.
Just another data point for consideration.
-Sebastian Vettel
Old 05-07-2012   #5
Re: Project V8killa
Nice looking car. 6266 would be a nice turbo. I personally wouldn't go any larger at first because that turbo will get you some damn nice numbers. Just make sure the rest of the car is ready for it. I'm not familiar with that clutch, but hopefully it works out? I really liked my 2900/Clutchnet combo. It's what a handful of people on the Link forums were running with good results. Something to consider if yours ends up not holding.
Good luck!
Old 05-07-2012   #6
Re: Project V8killa
Can't wait to see this go together. I'd spend the $$$ and go 6266 over a holset thing, unless you wanted to go 5858, which I think would be awesome and I've seen break 600before with room to go.
I did more than just give you a plan.
Old 05-07-2012   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
I was thinking a 6262 journal bearing in a bolt on housing and a FP race if funds get low. But as of right now plan is a 6266 t3 top mount exhaust mani. The only thing is there's a $1500 difference in the set up. So I'll have to see where my money's at as it's the last thing I'm buying.
Halan these are the clutches I'm talking about.
http://www.tmzperformance.com/Mitsub...%2520Kits.html
Old 05-07-2012   #8
Re: Project V8killa
Top mount is just for show, so if that's what you are going for cool. If not they were built for 42R shits and well 90% of people don't even need those with all the new turbo tech around.
That is kinda my plan, do a bolt-on housing for now and see what it can do.
So what needs to be done to the new shell as of now?
Old 05-07-2012   #9
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
Well with the advice of Shane and a few other shops they said the cometicwould do the job with L19s. So I'll give it a shot I also plan on o-ringing the head for extra insurance.
Old 05-07-2012   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
I'm currently pulling the black stuff out of my old shell to put in the new one then just wait for parts. My walbro 450 should be here by the end of the week so I might install that over the weekend, put in all my gauges, and black interior.
Am I going to be fine with the stock rail stock lines? I have an feed lines from the filter but that's it as of now. Also I plan on staying on plugs and wires just gonna get a spark box like a dynatex? Don't know how to spell it lol
Old 05-07-2012   #11
Re: Project V8killa
You can calculate pressure drop across the lines and then the head pressure needed to push it up to the fuel rail and determine if your pump is enough. If it is similar in nature to a 3000gt/stealth at around 11' of 5/16" feed line, you are looking around 4psi pressure drop at 448 lb/hr of flow, with a velocity of 4.81 feet per second (starting to get very swirly)
How much power are you looking to push with your fuel pump? The walbro 450 should be better than my DW301 and my DW301 +1000cc's should support around 600AWHP without getting a hardwire around 35psi base fuel pressure or 25psi boost pressure (flow rating at 60psi).
Simply put, you'll only need lines if you want to help your fuel pump out. With injectors that size, I'd be more worried about return line sizing and fuel pressure regulator sizing to ensure you can get the baseline fuel pressure to a level of sanity.
Old 05-07-2012   #12
Re: Project V8killa
The stock fuel lines should be fine. The bottle neck will be the banjo bolt coming out of the filter. Getting a new feedline that ditches that banjo bolt should be enough, I'd just run -6. For more reassurance you could upgrade to a higher flowing filter while you are at it too. That's how I ran with my 62mm setup, worked just fine and isn't too rough on the wallet.
Old 05-07-2012   #13
Re: Project V8killa
Looks good Nick! Going to be an awesome project!
Let me know if you ever want any help.
Old 05-07-2012   #14
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
I'll let ya know for sure. I'll need help with the BAP for sure and now maybe running an lines.
Thanks
Old 05-07-2012   #15
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
Thanks those are the small things I wanna get figured out while the motor is being put together.
Old 05-07-2012   #16
Re: Project V8killa
I'd leave the lines unless a 2g has extra small lines. Plenty of people have made over 600 on stock lines,
Old 05-07-2012   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
Yeah I think with this pump the BAP is really not needed but we will se. I know scheides uses one on his 400. Also came with the car so I didn't buy it. The line to the fpr is an not sure size and the return is an but not to the tank.
So you think I should just get a an an line back to the tank and leave the feed alone.
Thanks guys for the help already. I wanna really put the money where it's needed. So tgis is definitely helpful.
As far as power 600hp on Shanes dyno would be cool
Old 05-07-2012   #18
Re: Project V8killa
No. I think you should leave all the stock lines in place. The bottleneck is at the top of the fuel filter (in your engine bay). That banjo bolt is the bottleneck. All I would do is use an aftermarket Feed Line (from the filter to fuel rail) that eliminates that banjo bolt. Then if you want some extra reassurance, you can replace the fuel filter with a higher flowing one, but that may not be neccessary. Also an after market FPR if you haven't already done so since you'll be moving a lot of fuel, it'll overrun the stocker at idle.
Running a line all the way to the tank may help a little, but I think it's not completely neccessary and that money/time/effort could be better applied elsewhere.
Old 05-07-2012   #19
blackawdtsi
Drives: 2G DSM
Re: Project V8killa
Since Jungy cut the feed and coupled it back together because he didn't run the Bosch, I'd either buy a new stock hose or run AN. One of the things I would've changed last winter if I kept it. Relying on alligator clamps for fuel hose isn't exactly ideal.
Old 05-07-2012   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Project V8killa
Stupid iPhone
