Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 05-16-2012   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
PG SA/U Roll Call Thread
I saw talk of it on the PG SA thread so hell, I figured I would start it.
Who's in? I am not as familiar with the DSM setups, mostly evo setups so curious who all will be in this class?
I have serious doubts about my car making it there, but I will do my best. I am going to be there spectating at a minimum. But if I race it will be SA/U for sure.
So, who be in??!
Old 05-16-2012   #2
Re: PG SA/U Roll Call Thread
I might be, depends if i get to use slicks.
Old 05-16-2012   #3
Tachyon
Tachyon's Avatar
Drives: Icarus
Yes you can!
As long as you install a VCE and go FWD...
Just a repost of the SA/U rules:
  • Stock frame turbocharger
    • External wastegates are acceptable in any configuration
    • Intake and Exhaust manifold upgrades are acceptable in any configuration
    • 2G DSMs may run TD05H variations (14B, 16G, etc)
  • Must have full exhaust that exists behind rear tires
  • Unlimited fuel modifications (alternative fueling allowed, injection of methanol and nitrous allowed)
  • Any ECU mods allowed (standalones allowed)
  • Tire Restrictions
    • AWD/RWD -- DOT approved drag radials
    • FWD -- Slicks up to 24.5"
I'm in of course. I am really anxious to fix my daily driver so I can crank the power on the Talon and test!
-Sebastian Vettel
Old 05-16-2012   #4
There might need to be more comment on evo turbos in there, unless they all the bolt-ons look stock.
damn it, they should let awd/rwd run slicks too!
Old 05-16-2012   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
I asked for clarification last year (from MAP) and I was told as long as it was 'bolt-on' you were ok.
This of course could get really out of hand if a person were creative.
-Sebastian Vettel
Old 05-16-2012   #6
Murlo26
Murlo26's Avatar
There are all kinds of evo bolt ons. I think ATP even makes a 35r bolt on which is stupid looking but they make it.
I am pretty sure the rules for SA include a stock compressor cover so even many actual bolt on turbos (EF3, EF4 etc) won't make SA because they use the bigger comp cover.
Old 05-16-2012   #7
Murlo raises a good point, if not you could use a bolton 6266 even.
Old 05-16-2012   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
They are not going to limit you to a stock compressor cover in SA/U -that's what SA is for. The rules for SA state, "Compressor / turbo inlet must be stock size." SA/U mentions nothing of the like.
-Sebastian Vettel
Old 05-16-2012   #9
Murlo26
Murlo26's Avatar
Correct, I know SA/U isn't I was simply saying SA had a compressor limit. All that is limiting SA/U is its title...stock appearing!
Sure you can bolt on a 6266 but is that stock appearing...ummm no, lol.
The class is made for the larger appearing stock frame turbos basically. All of them should be MHI turbo based i'd assume.
Old 05-16-2012   #10
Tachyon
Tachyon's Avatar
Drives: Icarus
This is what I gather as well. If one were to fix a HX40 housing to a bolt-on turbine, I think there might be a judgement call enforced.
I know the "U" class was designed under feedback from a lot of us here to accommodate the most common type of turbo built car you would see on the street, while keeping it competitive for those who do have fully stock turbos (evo SRT MS3), in standard "SA"
While I've seen nothing prohibiting a massive bolt on setup, I think the gentleman's agreement here would be to run in a faster class. I know I would if I had a 60lb/m turbo on a lighter car.
-Sebastian Vettel
Old 05-16-2012   #11
I thought it was stock appearing turbo, but the unlimited part was everything else.
Old 05-16-2012   #12
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
I know someone that has an Evo HTA FP Red for sale... just sayin'
...I classed my way out of any hope of being competative.
Me and Troy will be holdin' down KS/U with high 10's... haha.
bramagedained is offline   Reply With Quote
Old 05-19-2012   #13
Pfft, Bryce will be pwnin you guys with 650 dynojet, he's got the driver mod
Old 05-17-2012   #14
^Hopefully.
There were more low 11s in the 130s last year, the honda guys will be the ones to beat in that class IIRC.
Old 05-19-2012   #15
MorningWood
Drives: Evo 8, 2014 Silverado
bryce wont be in that class, Mine and josh's are 64mm compressor wheels Bryce can luckily race the lower class haha
MorningWood is offline   Reply With Quote
Old 05-19-2012   #16
bramagedained
Drives: EVO IX SSL
Yeah, we lose because of 2mm.
Old 05-20-2012   #17
Oh shit, you guys prolly get to try to hang with cars like leasures 1g, and the other 42R cars huh?
Old 05-20-2012   #18
bramagedained
Drives: EVO IX SSL
Yeah, that's why the jokes.
Why in RACECAR class?
Because STREETCAR.
Old 05-20-2012   #19
because kool kids highway roll!
Old 05-21-2012   #20
bramagedained
Drives: EVO IX SSL
