Old 05-29-2012   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Timing..
So what should I set my timing at on my built 2.0 liter? I have wiesco hd pistons, howard rods, brian crower 280 cams with kiggly racing beehive springs.
Standard 5° btdc?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 05-29-2012   #2
Re: Timing..
I generally go 8-10, although that doesn't mean much anymore with customizable timing maps from link and others. Bumping it up to 10 BTDC worked great back with TMO and or a VPC.
Old 05-30-2012   #3
Re: Timing..
I'd rock the standard so you can have a for sure baseline when tuning, plus like steve said you have all the control you need in link.
Good luck this year, you always run some good times Still on the 3065?
Old 05-30-2012   #4
Capinoy123
Capinoy123's Avatar
Re: Timing..
Yup. Still on the 3065. I just wanna get my car tuned to the T! In dsm link as my car builds boost timing is falling and continues to fall through out the entire pull.... Not sure why?
Old 05-30-2012   #5
Re: Timing..
As engine load increases generally timing values will decrease until MBT is hit, then steadily increase as RPM increase, assuming load holds constant.
Old 05-30-2012   #6
Re: Timing..
I thought you don't want to increase over MBT no matter what?
From what I understand you want to try and increase timing with RPM until you hit that MBT point.
Old 05-30-2012   #7
Capinoy123
Capinoy123's Avatar
Re: Timing..
I know that timing retards as boost increases, but when I hit max boost 30 psi yhe timing is still falling. I guess im not understanding your question? What map am I using? Do you mean maf? If so im using a 3 1/2" gm maf. As for the load holding constant. Im 80% sure that it is. Checked for boost leaks 2 years ago, none. I know the weather can effect vaccum hoses over time so ill double check those, and do another boost leak test over the weekend. Checked compression, 180 across the board. What am I missing?!!
Old 05-30-2012   #8
Re: Timing..
MBT is dependent upon certain load and rpm combinations, it isn't a set timing value for all rpm point.
For example, let us say a car makes peak power with 10 degrees of ignition timing at 5000rpm and you rev to 7000rpm.
6000rpm, you may want 11 degrees of timing (to get to MBT again for that RPM/Load), and 7000rpm you may want 12 degrees of timing (to get to MBT again for that RPM/Load).
Old 05-30-2012   #9
Re: Timing..
what map r u on?
