Old 08-28-2012   #1
rx_08
rx_08's Avatar
Exclamation need some help!!!
Alright so here is the deal. I was driving down 94 the night before the cookout, and all of a sudden my car stutters a bit and loses power. I pull over to the side and the car dies on me. The cranks just fine but wont start up. I unplug the maf sensor and crank it, the car starts up and idles fine but when i plug in the maf sensor the car shuts off instantly. I've replaced the maf and the tps already and still the same results. Oh yea and the car is a gvr4 by the way.
mods:
2g maf
evo 560s
walbro 255
chip from shane for the set up
I am pretty lost at the moment on how to go about this situation. I've tried looking up similar symptoms online but no positive results. So if any of you guys have had similar situation and could give me a few ways on how you guys went about it, that would be awesome.
rx_08 is offline   Reply With Quote
Old 08-28-2012   #2
Re: need some help!!!
02 sensors? Or the wiring to them?
Old 08-28-2012   #3
rx_08
rx_08's Avatar
no haven't really messed with the O2 sensor at all and I haven't touched any grounds.
Old 08-28-2012   #4
timschot
timschot's Avatar
Drives: 2008 Evo GSR
You recently move any grounds?
timschot is offline   Reply With Quote
Old 08-28-2012   #5
timschot
timschot's Avatar
Grab someone else's known-good MAF, see if it does the same thing. And/or see if yours works in their car. Just start eliminating causes.
Old 08-28-2012   #6
rx_08
rx_08's Avatar
Yea that's where I'm lost now haha
Old 08-28-2012   #7
johnson
johnson's Avatar
Drives: 90mitsu
Could it be flooding the engine? Fouling plugs?
Old 08-28-2012   #8
timschot
timschot's Avatar
He said it runs w/o the maf, and dies as soon as he plugs it in.
Are there any codes showing?
If not, make sure it's not a coincidence. Does it die if you just let it sit for a while with the maf unplugged? Does it always die the second you plug the maf in?
If you can verify there are no codes and it is definitely occurring when the maf is plugged in ONLY, then you either have a maf, wiring, or maybe an ecu problem. You could try resetting the ecu (just unplug the battery and go watch a tv show or something), but your best bet is just finding someone with the same maf that is in obvious working order and swapping it. If your car runs with their maf, then it's your maf. If not, then it's something else. Corroded wires, rusted out grounds, blown fuse/relay... good luck.
Old 08-28-2012   #9
Pull the ECU and pull the cover off and look for burnt stuff, and if it smells like rotten fish there are issues. If you unplug the MAF it should default to RPM vs TPS, so either you have another bad MAF, faulty wirering, dropped tune, or an issue in the ECU.
Old 08-29-2012   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Did you clean the pins on the maf pigtail? Boost leak test? Having the maf plug off will throw it in limp mode and allow it to run rich with major leaks. As soon as you plug it in it will read normal but die cause of leaks
Old 08-29-2012   #11
rx_08
rx_08's Avatar
I checked the ecu and there were no burnt caps or anything, and as for the maf it was running fine with the 2g maf for a few weeks now just recently died. Replaced maf with another and same results.
I have not checked for corroded pins yet so ill do that, and I've done a boost leak test already and no major boost leak but ill probably do it again.
Thanks again ill try these ideas and see if it works.
Old 08-29-2012   #12
Check the fuse for the alternator, they do all kinds of crazy stuff if that blows and no 2 cars seem to do the same thing. After that I would agree with John and try out another ECU.
Old 08-29-2012   #13
rx_08
rx_08's Avatar
yea i've tried another ecu already and same thing happens. so ill have to check for corrosion in the wires or boost leak test again.
Old 08-29-2012   #14
talonite
talonite's Avatar
Drives: 1997 Eagle Talon TSI
sure you dont just have a massive air leak?
talonite is offline   Reply With Quote
Old 08-29-2012   #15
johnson
johnson's Avatar
Drives: 90mitsu
Do you have any gas?
I checked it out tonight, it runs fine with the maf plugged in, as long as i am manually blowing air through it.... Feels like there is no suction of air from intake at all? So either im thinking a major boost/vacuum leak or NO gas! Hahaha..... Other than that i got it to run with the maf plugged in!
Old 08-30-2012   #16
rx_08
rx_08's Avatar
gas was pretty low but it was running with maf unplugged.... haha so I don't know..
Old 11-21-2012   #17
rx_08
rx_08's Avatar
Alright so I've finally found some time to mess with the car again and I switched out the tps, tried a few mafs, did boost leak test, and no corrosion on pigtails but car is still not running...... Damn, help me out...
Old 11-21-2012   #18
Pull the plugs after it runs poorly and see if it's running super rich or super lean, then trace back from there.
Old 11-22-2012   #19
rx_08
rx_08's Avatar
I don't have a wideband.
Old 11-24-2012   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
You don't need a wideband to look at your plugs to see if its rich or lean.
